ᐅ Is there an easy way to repaint Ikea Besta doors afterward?
Created on: 24 Feb 2015 08:13
RigrahamHello everyone,
I have a question that has probably been discussed before, but I would like to ask it in detail to get targeted answers: Is there a simple way to repaint Ikea Besta doors afterward without fully sanding them down or completely repainting?
I’m especially interested in the best approach if the doors are already installed and I want to avoid extensive disassembly and intensive sanding.
Which materials (paint, primer) are suitable to ensure the paint adheres permanently to the surfaces of the Besta doors? What surface preparation is needed if the doors, for example, already have a foil or a painted finish?
I look forward to your experiences and tips on how to achieve this as easily as possible while ensuring durability and a good appearance.
Rigraham schrieb:
Is there an easy way to repaint Ikea Besta doors afterwards without fully sanding them down or repainting completely?Hello Rigraham,
yes, there is a practical method to repaint Besta doors afterward without completely removing and sanding them down. The key is proper preparation:
- First, thoroughly clean the surface to remove grease and dust. A degreasing cleaner or a special wallpaper adhesive remover works well here.
- Next, lightly sand the surface with fine sandpaper (grit 220–240). The goal is to slightly roughen the smooth foil or coating so the new paint can adhere. It is not necessary to sand down to the wood.
- After sanding, carefully remove all sanding dust.
- For priming, I recommend a bonding primer specifically designed for smooth plastics or laminated surfaces. This will improve the adhesion of the topcoat.
- Then you can paint with acrylic lacquer or a two-component (2K) topcoat in the desired color. Using a paint roller or spray technique will give a smooth finish.
Important: For doors still attached to the furniture, make sure to mask hinges and adjacent areas carefully. Also, consider the frequency of use and mechanical stress—sometimes it’s better to remove the doors for painting.
If you pay attention to this, only sand the foil very lightly to avoid damage.
In summary: It’s not complicated, but some preparation is necessary to achieve a durable result.
BauSimon schrieb:
For priming, I recommend an adhesion primer specifically designed for smooth plastics or laminated surfaces.I agree with that. However, I would like to add that the type of surface is crucial. Besta doors often have a melamine-coated surface, which is extremely smooth and chemically inert.
To ensure good adhesion here, you should:
- Use a sanding pad (not coarse sandpaper!) to create a microscopically fine texture on the surface.
- Apply a 2-component (2K) adhesion primer – this significantly improves adhesion strength and delays paint peeling.
If the doors have a foil coating, improper sanding risks damaging the foil, which can later cause bubbling or peeling. You should check this.
An alternative can also be a specialized spray paint (e.g., polyurethane-based) without much priming; I have used this on similar fronts—with good adhesion and a nice finish.
Finally, a note: when painting edges and door fronts that are not fully painted, touch-ups always look somewhat makeshift. Either paint the entire element or consider a compromise with a foil overlay.
I would add that Ikea Besta cabinet doors often come with different surface finishes – ranging from decorative foil to lacquer and even real veneer.
If the surface is foil, a simple repaint with conventional paint is often not durable because the surface does not provide enough adhesion and lacks flexibility. In this case, an intermediate layer of adhesion promoter can help.
If the doors are more likely lacquered, a light sanding followed by a high-quality two-component (2K) paint with intermediate sanding is strongly recommended. Although this takes more time, it significantly improves durability and appearance.
A basic paint from a hardware store may provide a quick visual update but usually does not last long, especially on heavily used areas.
maureo schrieb:
I simply cleaned my Besta doors, lightly sanded them, and then sprayed them with spray paint from the hardware store.That might work initially, but please keep in mind that melamine-coated doors are generally not designed to be painted. Mechanical stress and indoor climate conditions can quickly cause cracking and peeling.
TEBILO schrieb:
An alternative could be a special spray paint (e.g., polyurethane-based) with minimal priming requiredI would strongly differentiate here. “Minimal priming” is, in my view, a risk because poor adhesion is almost inevitable. For a lasting result, planning the entire coating system—from primer to final paint—is crucial; otherwise, you will likely experience frustration due to peeling.
So, if someone prefers as little effort as possible, this might be a quick fix, but it should be clear that this approach is a compromise.
