ᐅ Is there an installation guide for the IKEA Besta system that includes technical components such as power outlets?
Created on: 26 Jun 2021 19:37
WaltraudsiW
Waltraudsi26 Jun 2021 19:37Good evening everyone,
I am currently planning an IKEA Besta furniture unit, into which I would like to integrate technical components, mainly power outlets and possibly USB ports. Since the standard IKEA instructions do not cover such modifications, my question is:
Is there a specially adapted assembly guide for the IKEA Besta system that shows how to install and securely mount technical components like power outlets?
I am interested not only in the mechanical installation but also in advice on cable management, securing the electrical components, and integrating them without damaging the furniture structure or compromising stability.
Perhaps someone here has already done something like this, or has a reliable source, sketches, or tips on how to best plan and carry it out?
I look forward to your experiences and suggestions!
Thierryzar26 Jun 2021 20:05Hello,
As far as I know, there is no official construction manual with technical installations for the Besta.
I would recommend using power strips with flat cables and securing them inside the frame with mounting adhesive or clips. Cable ducts attached behind the furniture piece are suitable for cable management.
Hello Waltraudsi,
I’d like to give a more detailed answer to your question, as custom builds like this are quite common. The key point is planning:
- First, you should decide which power outlets or technical components you want to install: standard electrical sockets, USB charging ports, or even HDMI/network connections.
- Then, consider where the power supply can enter the furniture without compromising stability or appearance.
- A useful first step is to make sketches documenting the dimensions and positions of the built-in components.
For the actual implementation:
- IKEA Besta furniture is made of relatively thin engineered wood, so it’s advisable to drill holes for outlets carefully and evenly with a hole saw to avoid splintering.
- For cable routing and recesses, you can use cable channels or flexible conduits. Make sure there are no sharp edges that could damage the cables.
- From an electrical perspective, ensure the installation does not lead to overheating and that all sockets are properly grounded. It’s best to consult a professional electrician for wiring the outlets.
In conclusion:
Unfortunately, there is no ready-made building manual as a PDF or similar because these installations are very individual. Some DIYers share their projects in blogs or forums with detailed photos and step-by-step guides, which can be a great source of inspiration.
If you like, I can also outline common pitfalls users often overlook, so nothing goes wrong.
In conclusion:
Waltraudsi27 Jun 2021 14:46LAURE-TA schrieb:
A sensible first step is to create sketches where you note down the dimensions and positions of the built-in components.Thank you very much for the detailed tips! I had already started on the sketches to precisely prepare the placements.
LAURE-TA schrieb:
Electrically, you should ensure that the installation does not cause overheating and that outlets are always properly grounded. It is best to consult a professional for operating the outlets.I think that is a very important remark. Although I plan to power the outlets only via an existing outlet with an extension cord, I still want to make sure there are no risks.
Does anyone have experience with how to conceal cable routing well without compromising the stability of the furniture? I am a bit concerned that drilling and routing could affect the stability.
Regarding the stability and safety of technical installations in IKEA Besta:
- The furniture is made of particleboard with a melamine coating, which is relatively thin (usually 16 mm (0.6 inches)). This means that larger cutouts in load-bearing parts can lead to a loss of stability.
- It is advisable to reinforce any modified areas with appropriate supports, such as metal brackets or additional strips on the inside.
- For electrical installations, the protection rating of the sockets must be strictly observed, and all connections must be installed according to relevant standards.
- Since IKEA furniture is not designed for electrical installations, there are no official construction plans or modifications that guarantee electrical safety.
In conclusion: If you do not have solid technical knowledge, the installation of electrical components should be checked by a qualified electrician. DIY projects are creative but involve significant risks when it comes to electrical installations.
