ᐅ Is there an app for planning IKEA Platsa solutions for small spaces?
Created on: 4 Apr 2021 09:17
wilburnar
wilburnar
4 Apr 2021 09:17
Good morning everyone, I am currently exploring the idea of planning an IKEA Platsa system in a very small space to make the best possible use of the available area. I am wondering if there is an app specifically designed for realistically and detailed planning of IKEA Platsa solutions for small rooms.
It is important to me that the app allows flexible adjustments of the module sizes and can handle room constraints, as I have very limited space and need to consider all relevant measurements. Additionally, it would be great if the planning software also offers the ability to simulate the appearance as accurately as possible, to better visualize the final result.
Has anyone had experience with such apps and can provide concrete recommendations? I would also be interested to hear how well the integration with the actual IKEA products works and whether the plan can be executed exactly as designed.
bapar
4 Apr 2021 11:43
Hello wilburnar, your question is very interesting to me, as I have planned with IKEA systems several times before, including Platsa. Basically, there are several planning tools available to design IKEA furniture, but unfortunately, IKEA does not officially provide an app specifically tailored to Platsa or optimized for small spaces.
The best available tool at the moment is the IKEA kitchen planner, which also supports Platsa modules – however, it is generally designed for larger kitchen spaces and is less intuitive for smaller rooms with many limitations. Still, you can customize RGB function frames and module dimensions individually, based on width, height, depth, etc. This is especially helpful if you stick to the typical module sizes.
Alternatively, there are third-party programs like RoomSketcher or SketchUp, where you can input the individual IKEA modules yourself if you know the measurements. This requires some time and technical experience, but in return, you have full control over the space and furniture selection. In any case, it is important to measure accurately so that planning for small rooms remains precise – especially since obstacles like baseboards, radiators, and door swing directions need to be taken into account.
I would be interested to know exactly how much space you have available and whether you have already taken the room measurements to better estimate how detailed the planning should be.
Taubi
4 Apr 2021 12:05
On the topic: No, there is no specialized app just for Platsa. The IKEA kitchen planner works well, although it is not perfect for small spaces.
fepau
4 Apr 2021 14:22
Great topic!! I designed my small room using Platsa with the IKEA planner, and despite its limitations, it worked out well. The planner isn’t perfect, but with a bit of patience, you can create great solutions! Don’t be discouraged, it’s worth it! 😊
Fitigu
5 Apr 2021 08:31
bapar schrieb:
The best available tool right now is the IKEA kitchen planner, which also supports Platsa modules – however, it is usually designed for larger kitchen spaces and is less intuitive for smaller rooms with many constraints.
I agree with this assessment. The IKEA kitchen planner is currently the most detailed, officially supported tool for the Platsa system, even though its focus is less on very small spaces.
Third-party planners like SketchUp can be an alternative but require significant effort for modeling and learning.
For your objective, it is essential to measure all room dimensions precisely and systematically transfer them into the planner. Pay attention to the following points:
- Document door openings, windows, and radiator positions
- Consider the modularity of Platsa elements (16 cm (6 inches) wide modules and 40 cm/60 cm (16 inches/24 inches) depth options)
- Check the maximum height and the integration of baseboards
If you want to simulate the appearance, the IKEA planner offers the best, albeit limited, options. For photorealistic visualizations, additional software or plugins are needed.
Tudogo
5 Apr 2021 09:14
Hello wilburnar,
I would like to add to what has been said so far that the IKEA kitchen planner was sufficient for me to create realistic designs for small spaces using Platsa. It is important to carefully measure your room and consider the standard cabinet sizes.
If you don’t want to model every variable in external software, the IKEA planner is the easiest choice. It also allows 3D visualization, so you can get a good idea of how the layout will look.
From my own experience, I also recommend visiting IKEA after your digital planning to see the cabinets in person, as some depths and heights often appear different in photos.
I am happy to provide more details if you like.
