ᐅ Is there a way to retrofit Ikea Besta units with glass fronts?
Created on: 6 Oct 2024 18:27
Elelchen
Elelchen
6 Oct 2024 18:27
I have a Besta system from Ikea, which I really appreciate for its flexibility and modular design. However, I have been considering whether and how these cabinets can be retrofitted with glass fronts, as I would like to achieve a slightly more elegant or modern look.
My exact question is: Is there a way to add glass fronts to Ikea Besta cabinets afterward, without having to buy completely new doors or replace the entire carcass? If so, what are the practical steps and necessary materials? Are there perhaps special attachments or glass panels that can simply be installed?
I look forward to your tips and experiences, whether DIY solutions or official IKEA parts. Thanks in advance!
Paunon
6 Oct 2024 18:49
yes, there are retrofit kits or individual glass panels that can be ordered separately from Ikea. Alternatively, you can have suitable glass panes cut to size and fit them into a frame yourself. However, these options are not original Ikea products and require some DIY skills.
gregto
6 Oct 2024 19:03
Hi Elelchen,
your question is very well formulated and important, as many Besta users feel uncertain about such modifications. Generally, Ikea Besta fronts are not always standardized for glass, so you can’t simply attach glass doors.
However, there are options, such as replacing the original doors with glass doors from Ikea’s range, which is usually the cleanest solution. For retrofitting glass fronts without replacing doors, it is often recommended to attach wooden frames with inset glass to the existing carcasses—glazing beads can help secure the panels. Here, you should definitely pay attention to the exact dimensions of the Besta frames and measure them beforehand if necessary.
If the main goal is the visual effect, frosted glass or tempered safety glass (ESG) is recommended. Safety glass offers particularly good slip resistance and stability.
If you’re not very experienced with DIY, a cabinetmaker could also assist by creating custom solutions.
I hope this helps for now!
fredle
6 Oct 2024 19:18
I’d like to share a brief guide on how to approach this topic:
- Step 1: First, accurately measure the existing doors to have suitable glass panels cut or to purchase appropriate frames.
- Step 2: You can order original Besta frame doors directly from Ikea if you want a full door upgrade.
- Step 3: For retrofitting without replacing the doors, consider installing glass panels into the existing door frames or using full glass stickers.
- Step 4: When installing, be sure to use appropriate glazing beads or silicone sealant to secure the glass and prevent it from slipping.
- Step 5: For DIY projects, safety glass (tempered glass) is recommended as it is shatter-resistant.
Common mistakes include incorrect measurements or improper securing of the glass panels, which can cause them to not hold properly or result in doors sticking.
Conclusion: Retrofitting is possible, but it requires planning and some level of DIY skill.
RENMA
6 Oct 2024 20:46
The question of retrofitting glass fronts on Ikea Besta units is certainly justified, but it is important to clearly differentiate between:
- Original replacement parts from Ikea
- Third-party solutions
- Custom builds
Ikea only offers glass fronts as complete doors. Retrofitting existing doors—such as adding a glass panel to wooden or MDF doors—is not planned and is technically difficult to achieve without significant modifications.
Additionally, Besta frames are usually grooved and designed to support their doors independently, which can lead to stability issues if using a glass panel without a frame.
Some third-party suppliers offer solutions with aluminum frames and glass, but these often lack perfect fit and warranty coverage.
In short: only replacing doors with original or properly fitting glass doors is truly straightforward; otherwise, the effort is substantial and the stability questionable.
lisku
7 Oct 2024 08:13
Response to retrofitting: The best option is to buy completely new glass doors. Simply fitting fixed glass panels into the frame usually does not work due to the lack of a proper frame. Alternatively, glass films can be applied to existing doors if a genuine glass appearance is not required.
