ᐅ Is there a way to modify Ikea Brimnes furniture to make it smaller?
Created on: 25 Nov 2018 14:23
Ferminsa35
Hello everyone, I have the following question: Is there a way to reduce the size of Ikea Brimnes furniture, for example by shortening individual parts or rearranging the modules? I want to adapt the furniture pieces to fit a smaller space without having to buy completely new furniture. I’m interested in whether the material can be worked on easily using common tools or if there are specific structural limitations that would make this impossible. Does anyone have experience or ideas on how to customize Brimnes series furniture like wardrobes, dressers, or shelves to fit specific dimensions? Thanks in advance for your insights!
GALEO4
26 Nov 2018 13:27
Garth49 schrieb:
It is also important that all load-bearing elements remain intact; otherwise, the entire piece of furniture will become unstable.
I completely agree, even though I am generally skeptical about IKEA furniture: Many people think they can just cut it to size, but the design is based on specific dimensions and connection points. Cutting it can cause the parts to no longer fit together properly.
In my opinion, if you want flexibility, you should opt for modular or DIY systems rather than cutting the Brimnes. A custom-made piece tailored to the exact measurements is better—though it might require more effort, it is safer and more durable.
Wesley
27 Nov 2018 08:04
Hey, about the theory: In practice, I’ve seen a lot of things that were possible! 😅
Some people simply adjusted the side walls or swapped the front panels, even covering modifications with decorative films or paint. Well, of course, it’s not solid wood, but with a bit of creativity, you can create really stylish one-of-a-kind pieces.
I’d say: grab your screwdriver—but first, plan and measure carefully! And always keep stability in mind.
Good luck with it! You can do it! 👍
raelto
27 Nov 2018 11:19
For factual clarification:
The IKEA Brimnes material primarily consists of melamine-coated particleboard with a thickness between 12 and 18 mm (0.5 and 0.7 inches). Cutting is technically possible, but:
- Precise cuts require appropriate tools, such as a circular saw with a fine-tooth blade and dust extraction.
- Cut edges must be finished with edge banding or edge protection, as the melamine coating tends to chip otherwise.
- Load-bearing parts should be modified with caution to avoid compromising structural strength.
- New drill holes must be accurately placed, especially for hinges and fittings.
I recommend having spare fittings on hand and, if necessary, using auxiliary materials like connector strips. Alternatively, redesigning the interior or repurposing the space often provides a better solution.
Be sure to test on a sample piece or damaged furniture part before starting the modification.
