ᐅ Is there a way to protect Ikea PAX wardrobes from moisture?
Created on: 19 Aug 2024 08:43
Dana58
Dana58
19 Aug 2024 08:43
Hello everyone, I recently bought an Ikea PAX wardrobe for my bedroom because I really need the extra storage space. However, the room can sometimes be a bit damp, especially in winter, as the heating doesn’t run continuously. My question is: Is there a way to effectively protect Ikea PAX wardrobes from moisture and prevent the materials and built-in furniture from mold or moisture damage? I have already considered using silica gel or special water repellents, as well as a particular installation method that allows for air circulation. Maybe someone here has practical experience or good tips on how to make the wardrobe as moisture-resistant as possible without having to opt for more expensive specialist furniture. Thanks in advance!
KLO-KA
19 Aug 2024 09:05
A tip: Do not place the PAX wardrobe directly against an exterior cold wall; instead, leave at least a few centimeters (inches) of space for air circulation. Also, use dehumidifiers or silica gel packets inside the wardrobe. This helps prevent moisture and mold.
lyndon
20 Aug 2024 15:22
Just a quick note: PAX drawers and carcasses are made from coated particleboard, which only tolerates moisture to a limited extent and can swell if exposed to prolonged dampness.
An effective measure is to improve air circulation behind and inside the wardrobe. This can be done by partially removing the back panel or creating ventilation holes.
I also recommend placing dehumidifiers both in the room and inside the wardrobe to keep the relative humidity low.
Impregnating the wardrobe surfaces makes little sense because the material is already impregnated, and paints or other treatments do not adhere well. Instead, preventive climate control—meaning heating and ventilation—is the best protection.
Dana58 schrieb:
My question is therefore: Is there a way to effectively protect Ikea PAX wardrobes from moisture and preserve the material and built-in furniture from mold or moisture damage?
So, this can only be managed by controlling humidity, not by targeted sealing.
likuken
21 Aug 2024 11:17
Interesting point here: Why place a PAX unit in moisture-sensitive areas at all? Everyone giving advice always talks about ventilation and spacing, but honestly, if the room isn’t dry, none of that helps much.
lyndon schrieb:
preventive climate control, meaning heating and ventilation, is the best protection
Sure, I assume everyone tried that before setting up the cabinet.
I’m waiting for the first person to say that cheap furniture is just cheap furniture—and in damp corners, it’s simply not meant for long-term use. If you really want long-term protection, you need to invest more or choose furniture made from different materials. Everything else is merely cosmetic.
Davidleo
22 Aug 2024 19:51
Hello everyone! I can only encourage Dana58: You can achieve quite a lot even with the PAX wardrobe! 🙂
I also have my wardrobe in a more humid room and installed silica gel packs, which I replace regularly. I also make sure there is at least 5 cm (2 inches) of space behind the wardrobe – that really makes a difference.
In addition, I attached small magnetic ventilation openings to the doors, which are hardly noticeable but improve air circulation. This way, I was able to completely prevent mold!
Keep it up, the combination of air circulation, dehumidification, and occasional ventilation is really valuable! Good luck!
