ᐅ Is there a way to protect Ikea Metod cabinet fronts after installation?
Created on: 22 Sep 2020 08:37
mathisjeHello everyone,
I am currently looking into whether there is a way to protect Ikea Metod fronts retroactively so that they become as resistant as possible to scratches, moisture, or discoloration. My main concern is when the kitchen fronts are already installed, as I want to compensate somewhat for everyday wear and tear and increase their durability.
Does anyone have experience with special sealants, varnishes, or other methods to protect the fronts without significantly affecting their appearance or feel?
Thank you very much for any tips and advice!
Hello mathisje,
In general, Ikea Metod fronts usually come with a melamine or lacquer surface, which already provides some level of protection. If you want to improve the protection afterward, the following options are mainly available:
- Clear coats based on PU or acrylic lacquer: These can be applied to the surface and create an additional layer against scratches and moisture.
- Special surface sealants such as clear coat sprays or satin-matte lacquers.
- Alternatively, protective films, which can often be difficult to apply on kitchen fronts.
It is important that the surface is absolutely clean and grease-free before application, and that the lacquer is fully cured. Keep in mind that applying lacquer can slightly change the appearance, usually making it a bit more matte or glossier, depending on the product.
It is best to test on an inconspicuous area before full application.
Hey mathisje and jaanda,
I actually applied a clear coat to my Metod fronts afterwards—just to add a bit of extra protection against kitchen wear and tear 😊. When doing this, I always make sure to:
- Apply the clear coat in thin layers.
- Let each layer dry thoroughly before applying the next.
The result: noticeably fewer scratches, and moisture beads off really well. Of course, the surface does feel a bit different afterward, but I don’t find it bothersome—more practical, actually!
Maybe this helps you as a reference!
Demetrius23 Sep 2020 07:43I understand that you want to increase durability, mathisje. It is always a bit frustrating when kitchen cabinets get damaged quickly, even though you are careful. I have personally experimented with different protective coatings as well, but sometimes it feels like you never quite achieve the optimal protection. I would be interested to know if anyone has been able to cleanly remove the protection in case the first application was not satisfactory.
Genevieve23 Sep 2020 09:19Demetrius schrieb:
I have personally also experimented with different protective coatingsThis makes me think: Don’t you think that the diffusion properties of the panels might change due to the various layers of paint?
Could it be that too many coatings ultimately lead to stresses or discoloration? I would appreciate it if someone could share studies or clear experiences regarding the long-term effects of these additional paint layers. Just because a clearcoat provides protection doesn’t, in my opinion, mean it is ideal for all Metod fronts.
