ᐅ Is there a way to make the assembly instructions for the Ikea Brimnes series easier to understand?
Created on: 26 Oct 2023 08:37
BEBEBAU
BEBEBAU
26 Oct 2023 08:37
Is there any way to make the Ikea Brimnes assembly instructions easier to understand?
I recently tried to assemble my Brimnes wardrobe and struggled several times with the instructions. The illustrations and individual steps often seem unclear, so you sometimes have to guess which parts go where or which screws to use for how long.
Does anyone know of ways to better understand or supplement these instructions? Maybe tips for alternatives like videos, practical additions to the drawings, or even methodical advice to work through the steps more efficiently and with less stress? I would be very grateful for concrete suggestions, as this half-guessed but tedious process is causing me unnecessary time loss and frustration.
kautra
26 Oct 2023 09:14
I would recommend sorting all the parts first and laying them out according to the drawings. Then, measure the screws step by step and note them down on a sheet of paper to avoid confusion. This usually helps to understand the drawings more quickly.
U
uslis47
26 Oct 2023 10:57
I’m very familiar with the frustration of IKEA instructions. In my experience, it often helps to review the manual roughly before starting the assembly. If possible, watching an assembly video at the same time can clarify many detailed connections. Additionally, I recommend adding special markings to the parts, for example with small sticky notes.
It’s also useful to take your time to carefully study the illustrations, especially the perspectives. Sometimes the drawings don’t clearly show all screw positions, so working step by step and double-checking your understanding before each step is helpful.
If you’re wondering: the IKEA website often provides additional tips and sometimes videos that can be useful. If there isn’t a video specifically for Brimnes, a general IKEA assembly series showing similar constructions is worth watching.
BEBEBAU
26 Oct 2023 12:11
uslis47 schrieb:
In my experience, it often helps to quickly review the instructions during the initial assembly before starting.
That’s a good point. I often started right away without getting the full picture and jumped from step to step. The idea of marking the parts with small labels first also sounds very helpful.
A question for those who find the drawings difficult to interpret: Is there a recommended approach for understanding details that seem ambiguous? For example, different screw types that look similar but have varying lengths?
I’m asking because I got stuck exactly there and didn’t see an easy way to clearly tell them apart without taking everything apart again each time.
JONSON
27 Oct 2023 08:22
The difficulty of distinguishing similar screws in the instructions is a well-known issue with many Ikea furniture pieces. My advice: before starting, lay out all screws and fittings sorted by size—ideally on a labeled surface. Note the quantities and dimensions to prevent mix-ups and save time in the end.
Additionally, I recommend having a good screwdriver and a small magnifying glass ready, especially if the illustrations are very small or unclear.
Another practical tip: set up good lighting so the small details in the illustrations are easier to see. This significantly improves the accuracy of the assembly.
mauka
27 Oct 2023 13:15
Honestly, this Brimnes madness has probably felt like a little adventure more than once, right? 😅
Still, Ikea wants to make our lives easier – but the instructions often look more like a visual minefield. You might even say that a bit more context and clear color coding would work wonders.
Maybe it helps to do it together with a friend; two pairs of eyes see more than one. And if you laugh about not understanding everything right away, the whole process becomes much more relaxed.
Just as a side note: I once created a simple system for instructions where you sort the screws into colored boxes to quickly see which ones you need while flipping through. Maybe someone would like to create something similar for Brimnes? 🤔
