Hello everyone, I hope someone here can help me. I have been considering using my Ikea PLATSA furniture in a damp room, specifically in the bathroom. My question is: Is there a way to make Ikea PLATSA furniture waterproof or at least treat it so that it can withstand moisture without developing mold, swelling, or warping? My idea is to somehow seal the surface or apply a special water-repellent treatment, but I’m not very knowledgeable about this and don’t want to make mistakes that could damage the wood. Has anyone had experience with this material or any tips on how to effectively and permanently protect PLATSA furniture from water? Thanks in advance!
Hey, what an interesting question! The PLATSA series is basically not designed for wet rooms, but with a bit of DIY care, you can achieve quite a lot 😄. I would recommend sanding the furniture thoroughly first to create a smooth surface that paint or sealant can adhere to well. After that, you can treat it with a waterproof clear varnish or a special wood sealant—preferably several thin layers to keep moisture out. Be sure not to forget the edges and drill holes, as they tend to absorb water! Alternatively, there are also waterproof films you can use to cover the furniture if the varnish isn’t enough. This way, you stay flexible and still have a nice surface. Good luck—may your PLATSA bathroom dream soon become reality!
Wood and water don’t mix – PLATSA is particle board and must be pretreated with a high-quality, waterproof sealant. Apply several coats of paint, paying special attention to all edges. Alternatively, use film or plastic coating. Moist areas remain problematic, so regular monitoring is important.
Hello Lekau, I would like to provide a more detailed guide on how to protect Ikea PLATSA furniture for bathrooms or similar damp environments. The main reason for moisture problems is the material: PLATSA is mainly made of particleboard, which swells quickly when exposed to moisture. Therefore, the following steps are recommended:
- Preparation: Disassemble the furniture and carefully sand all surfaces and edges to ensure good adhesion for the sealing.
- Primer: Apply a wood primer that is specifically moisture-resistant. This protects the wood and improves the adhesion of the finish.
- Sealing: Apply several coats (at least 3) of a waterproof acrylic or polyurethane varnish. Allow each coat to dry thoroughly and lightly sand between coats.
- Pay special attention to edges and drill holes, as water tends to penetrate there first.
- Alternatively, the furniture can be covered with waterproof foil (e.g., self-adhesive PVC foil) or sealed at joints with silicone.
Important: No method makes the furniture completely waterproof, but this procedure significantly reduces the risk of damage. Also, the furniture should not come into direct contact with water and should be well ventilated. I especially recommend sealing with polyurethane because it is particularly durable.
Franck schrieb:This is an important point that should not be underestimated. If you have questions about specific steps, I am happy to help.
Wood and water are not friends – PLATSA is particleboard, so it must be pretreated with a high-quality, waterproof sealant.
Marlenepa8 Dec 2023 09:14Hello Lekau and everyone contributing here! I would like to add a more practical perspective to the discussion. The PLATSA furniture is actually not suitable for highly humid or wet environments because, as mentioned, the material is sensitive. In general:
- Wood or wood-based materials such as particleboard are only somewhat water-resistant. You can protect the furniture, but the protection is not permanent.
- It makes sense to treat the furniture with a high-quality sealant (polyurethane or epoxy resin coatings). This takes time and some expense but lasts significantly longer.
- Pay close attention to properly sealed edges. Moisture tends to penetrate at the edges, causing swelling and deformation.
- Even after treatment, the furniture should not be exposed to water permanently, so avoid direct shower spray or splashes on the surface.
I find this to be a very valuable assessment to keep in mind. It is best to use the furniture in areas with little direct water contact or ensure good ventilation to improve its lifespan. If you find special moisture-resistant coatings, these are usually a better choice than standard paints.
I hope this helps you a bit!
Jensson schrieb:
Important: No method makes the furniture completely waterproof, but this approach significantly reduces the risk of damage.
Hello everyone, I’d like to add a few technical details to help better assess the possibilities.
PLATSA is made of particleboard with a veneered surface, which is not water-resistant by default. This means the boards absorb water, swell, and lose stability.
For truly effective treatment, keep in mind:
- Complete separation from water sources is important, so you should avoid water standing on or continuously running over the furniture as much as possible.
- If you work with varnishes, I recommend using two-component polyurethane varnishes, as these offer the best durability when applied correctly (temperature, humidity, intermediate sanding).
- The weak points are the edges and joints. Always treat these multiple times and, if necessary, supplement with sealants.
- Another tip is to avoid direct floor contact or at least use a waterproof base, as water often rises from there.
If you plan to use the furniture in the bathroom, it is generally advisable to keep moisture sources (e.g., shower, sink) away from the furniture.
If you want, I can also provide a list of products that have proven effective.
Exactly. Unfortunately, with wood-based materials, you cannot achieve permanent, 100% water resistance without professional processes and expensive materials. Nevertheless, you can significantly increase durability with careful preparation and varnishing.
Marlenepa schrieb:
Auch nach der Behandlung sollte das Möbel nicht dauerhaft Wasser ausgesetzt werden, also keine direkte Dusche oder Spritzwasser auf der Oberfläche.
