ᐅ Is there a way to make the Ikea Brimnes more stable?
Created on: 18 Jan 2017 07:42
Tanmin65
Tanmin65
18 Jan 2017 07:42
Some time ago, I purchased the Ikea Brimnes wardrobe, but I’m not entirely satisfied with its stability. Especially with the wider wardrobe units, the doors tend to wobble slightly, and the overall structure doesn’t feel very sturdy.
Now, I would like to know if there are ways to make the Ikea Brimnes more stable without having to replace all the wooden parts or take on major DIY work.
What specific measures can be taken to improve the wardrobe’s stability? Are there any tricks, additional reinforcements, different screws, or assembly methods that have proven effective?
Thanks for your tips and experiences!
flota
18 Jan 2017 08:33
Tanmin65 schrieb:
Now I would like to know if there are ways to make the Ikea Brimnes more stable without having to replace all the wooden parts or undertake extensive DIY work.
One of the most effective ways to improve the stability of the Brimnes is to add extra corner brackets on the backs of the carcasses. These reinforce the corners and especially prevent the doors from wobbling.
It can also help to retighten the screws and, if necessary, replace them with longer and thicker screws than those used in the standard configuration.
Reinforcing with a thin back panel (e.g., a plywood board instead of cardboard) can also contribute to increasing stability.
glapu
18 Jan 2017 09:01
In addition to the angle brackets, I also recommend securing the cabinet to the wall. This noticeably improves stability and prevents tipping movements.
Je_nau58
18 Jan 2017 14:17
flota schrieb:
Reinforcement with a thin back panel (e.g., plywood instead of cardboard) can also help increase stability.
That is correct.
Many IKEA cabinets, including Brimnes, use thin fiberboard back panels that provide little stability. Replacing them with a plywood panel about 4 mm (0.16 inches) thick significantly strengthens the furniture.
For attachment, small screws or special corner brackets designed for furniture can be used.
It is important to fully level the cabinet before final assembly and install the back panel fixed in place to achieve optimal stabilization.
elgla
19 Jan 2017 10:05
I can fully understand the problem, as I had the same issues with my Brimnes.
What helped me was adjusting the hinges slightly to reduce wobbling of the doors. Often, you only realize that small adjustments can have a big impact.
I also liked the idea of attaching plastic gliders to the bottom of the feet, so the wardrobe rests lightly on the floor and doesn’t move when touched.
None of these measures are complicated, but together they noticeably improve stability.
NOAHSAU
20 Jan 2017 16:59
Tanmin65 schrieb:
What can be done specifically to make the cabinet more stable? Are there any tricks, extra reinforcements, different screws, or assembly methods that have proven effective?
My impression: The Brimnes is not designed for heavy-duty use. If you want real stability, it’s better to go for solid wood furniture from the start.
However, if you’re working with the Brimnes, there are some creative options, like adding metal brackets or corner braces from a hardware store before assembly.
It won’t become ideal, but it will be somewhat more robust. Ultimately, it remains a compromise between lightweight design and sturdiness.
