Hello everyone, I have a question that I haven’t been able to find a clear answer to so far: Is there a way to make IKEA Brimnes furniture quieter? Specifically, it’s about the drawers and doors of my BRIMNES wardrobe, which squeak and rattle a lot when opened and closed. I have already tried tightening the screws and using silicone spray, but that only helped to a limited extent. I’m especially interested in whether there are mechanical or simple DIY solutions that can sustainably reduce or even completely eliminate the noise without having to take the furniture apart or make major modifications. Maybe someone here has had similar experiences or knows proven tips that go beyond the usual tightening and lubricating.
Hello Ezrabo, I’m very familiar with your issue. The drawers in BRIMNES furniture are often the main problem because the drawer slides have minimal damping. In your case, I would proceed as follows: First, check all screws and tighten them if necessary, as others have already recommended. Then, treat the slides with a high-quality, silicone-free lubricant, since silicone can become sticky over time.
It’s also important to install dampers made of foam rubber or felt at the contact points between the drawers and the frame. If that isn’t enough, small dampers can be attached to the hinges, similar to those used on swinging doors – this noticeably reduces noise when closing. If you want, I can give you specific product recommendations that I have tested myself.
RENMA schrieb:
Use of PTFE-based lubricants on metal sliding surfaces and hinges to reduce friction noise. That sounds very interesting. Which PTFE lubricants would you recommend that are affordable but work well in everyday use? Also, are there any potential risks during installation if too much lubricant is applied? Thanks for the tips!
klo61 schrieb:
It is also important to attach dampers made of foam rubber or felt at the contact points between drawers and the frame. Do you perhaps have examples of exactly where you attached the dampers? Is it inside on the sides or rather on the underside of the drawers?
Ezrabo schrieb:
Which PTFE lubricants can you recommend that are not too expensive but work well in everyday use?PTFE sprays from well-known brands like DuPont, Würth, or 3M offer good value for money and adhere well to metal surfaces. It is important to apply them sparingly, as too much lubricant can cause dirt buildup and trapped dust, especially in drawer slides. You should apply the spray to the moving metal parts—hinges, sliding rails, rollers. After applying, move the parts for 1-2 minutes to help the lubricant distribute. Wipe off any excess with a soft cloth afterwards.
Ezrabo schrieb:
Do you have examples of exactly where you mounted the dampers?Typically, dampers are installed on the inner edges of drawers, at the point where the drawer meets the carcass when closing, or on the guides where metal touches wood. Sometimes the inside surfaces of the drawer are good spots as well, especially where friction occurs. Alternatively, dampers can also be mounted on door hinges to soften the closing impact.
