Is there a way to make IKEA Brimnes furniture more stable?
I have several pieces from the Brimnes series, mainly dressers and bed frames, and I’ve noticed that they can become a bit wobbly under load or with frequent use. The construction is relatively simple, which is understandable given the affordable price, but I’m looking for practical and effective ways to improve stability without much effort—perhaps by adding extra braces, using stronger screws, or incorporating certain building materials as reinforcements.
Has anyone had experience with this or can offer tips on how to make the furniture more durable with minimal work? I don’t want to completely rebuild the items, but rather focus on reinforcing the weak points.
Rustamri schrieb:
Is there a way to make IKEA Brimnes furniture more stable?The Brimnes series is generally known for its lightweight design, which explains some stability issues. To make your furniture more stable, I recommend the following steps:
- First, carefully check that all screws are tight and retighten them if necessary—wobbly furniture is often caused by loose fasteners.
- Adding metal brackets or wooden braces to the back can significantly strengthen the structure. Usually, a simple bracket at each corner is enough.
- If the furniture has warped from use, it’s worth realigning the joints and applying some glue or good-quality screws to reduce movement.
- For bed frames, if possible, adding an extra center support or crossbar under the slatted frame can help.
It’s important that these modifications remain as reversible as possible in case you want to pass the furniture on later. Another tip: use high-quality screws and, if possible, dowels, since the original fasteners can sometimes be a bit weak.
Ulrichta schrieb:
Additional metal brackets or wooden braces on the back can significantly increase the stability of the structure.That is correct. The Brimnes series is made from particleboard with a thin veneer and standard fasteners, which are not designed to handle heavy loads over a long period.
Technically, you can improve stability by reinforcing the frame. Recommended measures include:
- Metal angle brackets on the inside corners behind the back panel
- Replacing or supplementing the back panels with 6–8 mm MDF boards (about 1/4–5/16 inches), glued and screwed for extra strength
- Enhancing connection points using longer screws or high-quality dowels
However, weight limits must still be observed. If the furniture will be subjected to heavier loads, it is generally better to replace the carcass material entirely. The above measures can extend the service life but do not substitute a solid wooden carcass construction.
If needed, I can provide a list of suitable materials and tools.
Rustamri schrieb:
Is there a way to make IKEA Brimnes furniture more stable?Add more screws, use metal brackets on the corners, and possibly reinforce the back panel by doubling it. This is usually enough to significantly reduce wobbling.
Leose schrieb:
Add more screws, metal brackets on the corners, and possibly double up the back panel.I can only agree with that, especially since the back panel on Brimnes is often too thin and therefore acts like a weak spine. A tip to reinforce the back panel:
- Carefully remove the existing back panel
- Attach an MDF board about 6 mm (1/4 inch) thick to the backside
- Secure it with enough fine screws and a strong wood glue
This significantly increases the furniture’s stability against lateral and torsional forces. Combined with additional brackets on the inner corners, you can achieve a lot without compromising the furniture’s design.
