ᐅ Is there a way to make IKEA Brimnes doors quieter?
Created on: 13 Sep 2024 09:48
Troylau
Troylau
13 Sep 2024 09:48
Hello everyone, I recently purchased an IKEA Brimnes bedroom furniture set and am generally satisfied with the doors, but I noticed they make quite a loud rattling noise when closing. This is especially bothersome at night when it should be quiet. Are there any practical solutions to noticeably reduce the closing noise of the Brimnes doors? I am thinking of dampers, silicone strips, or other simple retrofit options that don’t significantly affect the doors’ functionality. Does anyone have experience or tips? Thanks in advance!
GALEO4
13 Sep 2024 11:03
Let's be honest, IKEA furniture is mass-produced and designed for cost-effective manufacturing – so you can’t really expect high-end soft-close mechanisms. But the idea of making the Brimnes doors quieter is totally understandable.
Troylau schrieb:
Is there a way or practical solutions to noticeably reduce the closing noise of the Brimnes doors?
Looking at it from a different angle: maybe the noise itself isn’t a 'flaw' but rather part of the design? Still – I’ve heard of people attaching small furniture dampers or silicone pads to the door hinges. Whether this really helps is often more psychological than physical.
You could also consider DIY options – like small felt strips at the contact points or rubber bumpers. However, these solutions usually feel incomplete, and the doors often end up closing a bit stiffer. A quicker route might be to replace the hinges – but that involves some effort.
How important is complete silence to you? Or would just a slight noise reduction be enough?
Filippo
13 Sep 2024 13:27
Hello Troylau, I think your question is very good and important because many furniture users underestimate how crucial cushioning during door closing is for the overall user experience.
First, a few technical notes and suggestions that could help systematically:
- Understand the mechanism: The Brimnes doors use simple metal hinges without integrated dampers. This means the closing noise is caused by metal-to-wood contact plus the speed at which the door hits the cabinet frame.
- Retrofit dampers: There are special furniture door dampers (usually plastic with rubber buffers) that can either be glued inside the door leaf or screwed onto the cabinet. Important: Install them so the door closes more smoothly against the frame.
- Alternative cushioning materials: Felt pads, silicone, or foam rubber strips applied to the door’s contact points can soften the impact.
- Hinge modification: Some users have partially retrofitted hinges with integrated soft-close functions; however, these don’t necessarily fit Brimnes doors easily, as installation space is limited.
- Check adjustments: Doors are often not adjusted optimally, which increases noise levels. Precisely adjusting the door hinges (tightening or loosening screws) can already help a lot.
One question: Are your door hinges covered or fully exposed? How is the door stop designed? This might give further clues about how well retrofits will fit.
I hope this helps you already!
pikin
14 Sep 2024 07:53
As a supplement:
Filippo schrieb:
Precisely adjusting the door hinges (tightening or loosening the screws) can already help a lot.
This is indeed the first practical step to minimize unnecessary rattling.
In addition, I specifically recommend:
- Applying self-adhesive felt or foam rubber strips at the points where the door contacts the furniture. These are inexpensive and easy to install.
- Using small, transparent silicone bumpers that can be glued in spot locations. They provide a soft cushioning and remain invisible.
- Checking the hinges for a secure fit; loose hinges can also cause unpleasant noises when closing the door.
Suggested products should be suitable for cabinet doors to avoid any changes to the door alignment that could affect proper closing.
If these measures do not reduce the noise sufficiently, installing soft-close hinges is an option—though this involves more effort and usually a complete replacement.
This covers the range between simple solutions and moderate interventions.
nolan
14 Sep 2024 12:16
Stick felt strips to the contact points and adjust the hinges. If possible, install soft-close hinges. This significantly reduces the noise.
warrenka57
15 Sep 2024 08:39
I can understand well that loud doors can be very disturbing, especially at night.
I had a similar issue with my Brimnes wardrobe doors. After some research and experimentation, combinations of felt strips, silicone bumpers, and careful adjustment of the hinges helped me. It took several attempts to find the best balance between smooth operation and functionality.
Troylau schrieb:
That bothers me especially at night when it’s supposed to be quiet.
What I want to say is: it’s worth trying different methods and being patient. If you could briefly tell us how your doors are adjusted and if you have already tried anything, we can assist you more specifically.
I’m keeping my fingers crossed that you’ll have peace and quiet soon!
