ᐅ Is there a way to make the IKEA Brimnes close more softly?
Created on: 20 Mar 2016 09:17
MAMALO
I recently assembled the IKEA Brimnes wardrobe and am generally happy with its functionality. However, I find the doors slam shut quite hard. Is there a way to modify or retrofit the Brimnes wardrobe doors so they close more quietly and, above all, more softly? I have considered installing dampers or soft-close mechanisms but am unsure whether these would work well with this model or if they might damage the doors.
Has anyone had experience with this or can offer tips on how to make the Brimnes wardrobe close more gently without much effort or expensive solutions? Thanks in advance!
tuFernando
20 Mar 2016 12:13
MAMALO schrieb:
Appearance matters, but I would accept smaller visible dampers if they work well.
That sounds like a good solution to me. You could attach small whitish rubber dampers inside the corners.
I have used something similar in other cabinets, and it really helps with smoother closing, even if it’s not a professional soft-close. They don’t look bad, and especially inside, you quickly forget about them.
If it’s important to you, you can test the adhesive backing beforehand to make sure they don’t fall off due to temperature changes.
popodi
20 Mar 2016 12:41
I think with Brimnes it’s also about not adding too much "high-tech" – the furniture is designed more for everyday use. Sure, professional soft-close fittings are nice, but often small tricks are enough for a quick effect.
- Rubber cushions in the corners
- Door stops with bumpers
This makes things much quieter. If you do this as a set, you save money, and for the appearance: you can always adjust it with the next paint job. ?
leebi7
20 Mar 2016 13:05
MAMALO schrieb:
I really like the idea of the bumpers, but I’m not sure if they completely eliminate the "hard slam."
It won’t be 100% soft by default, of course. However, the rubber bumpers noticeably reduce the noise and protect the edges, which can otherwise suffer slight damage over time from slamming shut too quickly.
If you have the time and interest, you can also adjust the hinges by tightening the adjustment screws a bit. This makes the door glide more slowly into position instead of swinging open quickly.
I would suggest starting with the bumpers first and, if the result is unsatisfactory, consider soft-close mechanisms. But be warned, converting to soft-close requires compatible replacement hinges and some DIY skills.
parpeo
20 Mar 2016 14:18
I can well understand the perceived impact when the door shuts. I adjusted the hinges on a similar cabinet and also ordered self-adhesive dampers.
These are suitable because:
- They are easy to attach
- They do not significantly alter the furniture
- They reliably cushion the closing impact
If you decide to use self-adhesive dampers, pay attention to good quality; often you can find ones made of silicone or soft rubber, which hold well and leave no residue when removed later.
If you like, I can also explain in a few steps how to optimally adjust the hinges to make closing smoother.
MAMALO
20 Mar 2016 14:39
parpeo schrieb:
If you want, I can explain in a few steps how to properly adjust the hinges to make closing smoother.
That would be great if you could explain how to adjust the hinges. I have noticed that there are small screws on the hinges, but I’m not sure how these affect the resistance when closing.
I would also appreciate any tips on how to avoid mistakes during the adjustment process, so I don’t misalign or even damage the door.
parpeo
20 Mar 2016 15:03
Gladly! There are usually three adjustment options on IKEA hinges:
- Side adjustment (left/right): This allows you to move the door horizontally so it closes flush.
- Depth adjustment: How close the door sits to the cabinet frame.
- Height adjustment: Vertical alignment.
For a softer closing action, you can slightly tighten the screw that controls the closing pressure. This screw is usually located at the base of the hinge. But be careful: overtightening can cause the door to stick or damage the mechanism.
My tip:
- Make small adjustments (1/8 turn)
- Test the door by opening and closing it after each change
- If anything gets worse, turn it back
With a bit of patience, you can achieve a good setting without the door hanging unevenly or sticking.
