I have a specific question about the IKEA BESTÅ system: Is there a way to expand the modular concept of BESTÅ flexibly, not only by using standard IKEA extension parts but also by incorporating custom-made or third-party components to customize the system? Specifically, I am interested in what options are available if you want to use BESTÅ in a tailored way – for example, through additional modules, attachment possibilities, or compatible parts beyond the standard range.
My goal is to find out if and how BESTÅ can be expanded not only modularly but also in a scalable way without being limited to IKEA’s own products. Since the system itself appears to be quite flexible, I wonder if there are any experiences or known solutions to achieve this.
Thank you in advance for any information or practical tips!
traaugust16 Nov 2024 20:28Thank you for the previous responses.
[@Filippo, post: b1k7i0, member: XXX]
“How exactly do you want the extension to look? Do you want additional compartments, different dimensions, or even a completely separate module?”
That’s a good question. I am planning to expand existing BESTÅ units in the living room, which are 60cm (24 inches) wide and 64cm (25 inches) high, by adding more compartments and adjusting some dimensions. The idea is to go beyond the standard modules a bit, for example by adding intermediate levels or narrower additional shelves.
Specifically, I want to keep the system’s linear extension, but vary the depth or include smaller attachment modules, without visually breaking the system or causing stability issues.
Some kind of custom extension system that still looks seamless. Does anyone know of solutions like this or how to best achieve it technically?
Your idea sounds interesting and feasible, but there are some technical details to consider.
1. Material compatibility: IKEA uses MDF panels with a specific coating and thickness (mostly 16mm (0.63 inches)) for BESTÅ. If you use your own panels, they need to be visually and in terms of weight compatible.
2. Joining techniques: The standard connectors are cam locks and dowels, which are specifically matched to the panel thicknesses. For custom extensions, metal brackets, invisible connectors (e.g., slot connectors), or custom routed grooves are suitable.
3. Load capacity: Especially if you plan to add top modules or intermediate shelves, the load-bearing capacity should be taken into account. Stability can be improved with back panels or metal profiles.
4. Aesthetics: To maintain a consistent overall appearance, careful color selection and edge protection are recommended, as slight deviations become noticeable quickly.
If you want, I can provide you with a list of proven connectors and materials that work well for modular expansions.
traaugust16 Nov 2024 21:42[@Palenar, post: c9d8g3, member: XXX]
"If you want, I can provide you with a list of reliable fasteners and materials that work well for modular extensions."
That would be really helpful! I want to make the extension as stable and precise as possible, so specific advice on fasteners and materials would be great. I would also appreciate guidance on how to attach it to the existing structure and on load distribution.
Sure, here is a rough selection that has proven effective for upgrading BESTÅ:
- Metal angle brackets (heavy-duty version, at least 40 x 40 mm (1.6 x 1.6 inches))
- Screw-in angles with elongated holes to allow for some tolerance
- Steel connector plates for hidden fastenings
- MDF panels with 16 mm (0.63 inches) thickness, preferably with white foil or paint
- Strong beech wood dowels, 8 mm (0.31 inches) diameter
- Cam locks (IKEA originals or compatible ones if you want to keep it authentic)
- Thin hardboard back panels for added stability
For load distribution, it’s a good idea to use additional support feet or wall fastenings, especially with top modules. If you simply stack the carcasses, high loads can cause twisting.
In general, I recommend paying close attention to precise measurements and edge finishing when cutting the wooden parts to ensure everything fits together neatly. If needed, I can also provide tips for drilling and alignment.
traaugust17 Nov 2024 09:13Thank you for the detailed list; it really helps me a lot.
[@Palenar, post: d1h0x90, member: XXX]
"To distribute the load, it’s sensible to rely on additional support legs or wall attachments."
What interests me specifically is: How can you securely attach additional modules to the wall without damaging the original BESTÅ design? Are there special wall brackets from IKEA suitable for top-mounted or extension versions? And what is the practical approach to handling weight loads when stacking several units?
Maybe someone here has experience with sturdy wall installations for customized BESTÅ expansions?
The wall mounting of BESTÅ plays a key role in modular expansions, especially when planning top modules or wider constructions.
IKEA offers dedicated wall brackets for BESTÅ that can be attached discreetly. These are usually designed to be fixed from the inside behind the back panel, making them barely visible. Important points:
- Always install the back panel when expanding, as it increases lateral stability.
- If using your own materials or brackets, choose sturdy metal angles or rails. “Z-rails” or click-fastening systems are particularly useful here, as they provide some flexibility.
- Depending on the height of the extension, the wall mounting should be fixed at multiple points, especially with heavy loads.
For vertical extensions beyond the normal height, it helps to connect the modules as a single unit (by screwing or wedging) and anchor them together to the wall.
For additional safety, a support leg to the floor can be used, especially when the modules become tall. Overall, the rule is: the more connection points between the module and the wall, the more stable it will be.
