traaugust16 Nov 2024 18:03Hello everyone,
I have a specific question about the IKEA BESTÅ system: Is there a way to expand the modular concept of BESTÅ flexibly, not only by using standard IKEA extension parts but also by incorporating custom-made or third-party components to customize the system? Specifically, I am interested in what options are available if you want to use BESTÅ in a tailored way – for example, through additional modules, attachment possibilities, or compatible parts beyond the standard range.
My goal is to find out if and how BESTÅ can be expanded not only modularly but also in a scalable way without being limited to IKEA’s own products. Since the system itself appears to be quite flexible, I wonder if there are any experiences or known solutions to achieve this.
Thank you in advance for any information or practical tips!
The BESTÅ system from IKEA is intentionally designed to be modular, allowing expansions within the range of available modules. Beyond the standard offerings, extensions are only advisable if you have good DIY skills and create custom constructions using suitable fasteners. Stability is crucial in this process.
If you require customized sizes or different materials, IKEA does not provide direct solutions. Third-party components are not officially compatible and may cause assembly issues.
I think the modular appeal of BESTÅ is great – you can vary the setup easily with simple extensions. 😀 But of course, if you want to go beyond the standard cabinet sizes, it quickly gets creative. For example, you could cut the shelves yourself and combine them with suitable fittings if you’re handy.
Has anyone here tried something like this?
To address the original question more precisely: Expanding the IKEA BESTÅ system usually stays within IKEA’s guidelines by using original modules and accessories designed to be compatible.
From a technical perspective, this is possible because the module dimensions are standardized: 60 cm (24 inches) width is standard, which theoretically allows for connecting any number of units side by side or stacking them in certain versions. The connection is made via simple snap-on fittings and screws, which IKEA provides to enhance stability.
For DIY extensions – such as custom shelves, larger modules, or tailored components – it is important to ensure that the drill holes, materials, and frame correspond to the intended dimensions and load capacity, otherwise both stability and appearance can be compromised.
My specific recommendations are:
- Plan carefully with exact measurements (60 cm (24 inches) width, 40 cm (16 inches) or 64 cm (25 inches) height depending on the model)
- Use metal brackets or L-profiles for added stability in DIY constructions
- If cutting wood panels yourself, adjust the numbering of drill holes accordingly
How exactly do you want your extension to look? Are you aiming for additional compartments, different dimensions, or a completely custom module?
