ᐅ Is there a way to equip IKEA Besta rollers with brakes?
Created on: 28 May 2024 09:37
Kinenrique
Kinenrique
28 May 2024 09:37
I have a question that might concern some of you who have mounted or are planning to mount IKEA Besta cabinet systems on casters: Is there a way to retrofit the original IKEA Besta casters with an integrated brake?
The casters IKEA provides usually don’t have brakes, which can be problematic, especially for larger cabinets placed on uneven floors. I have considered either buying completely new casters with brakes or adding some kind of braking system to the existing casters.
Has anyone had experience with this or perhaps developed a DIY solution? What installation height and mounting considerations should be taken into account to avoid compromising the stability or appearance of the Besta system?
Thanks for your input!
GALENKU
28 May 2024 12:04
The original Besta casters do not have brakes and are not designed for them. I would recommend ordering casters with brakes of the same diameter and replacing the IKEA casters entirely. Retrofitting brakes onto the existing casters is technically very complex and usually not safe.
pikin
29 May 2024 08:18
In general: IKEA Besta castors are simple furniture wheels without brakes, typically with a mounting diameter of about 11 mm or 12 mm (depending on the model). Adding brakes to the existing wheels is difficult because their design does not allow for brake attachments and the dimensions are very compact.
- A practical solution is to completely replace the wheels with universal castors that have brakes and are of a similar size. It is important to pay attention to the maximum load capacity and installation dimensions to maintain stability.
- Another option may be separate brake devices for furniture that are placed between the floor and the furniture, although these usually provide only limited point contact and do not act directly on the wheel.
- Homemade brake systems, for example using clamping mechanisms, are generally unreliable and can impair function as well as damage the furniture.
Conclusion: The safest and most effective method is a complete wheel replacement. It is recommended to choose quality products that consider both weight capacity and appearance.
warrenka57
30 May 2024 10:47
GALENKU schrieb:
I would recommend ordering casters with brakes in the same diameter and completely replacing the IKEA casters.
I fully agree with this. I used to have the problem that my Besta shelving unit would move easily on laminate flooring without brakes, which occasionally made it unsafe. After a few days of trying, I bought universal furniture casters with integrated brakes that had the same diameter and simply replaced the IKEA casters.
It was important for me that the new casters were both load-bearing and not too tall, so they wouldn’t affect the appearance or compromise stability. This worked well, although you initially have to pay attention to the installation height.
If you just add a brake to the existing casters, there is a risk that the furniture will wobble or get damaged. In my experience, it’s best to replace the entire wheel. There might be suppliers offering specific replacement casters with brakes that fit Besta units perfectly – that would be ideal.
