I am currently working on planning a few DIY furniture projects and have a specific question: Is there actually a practical way to modify the IKEA PAX systems to make them better suited for DIY use?
I’m particularly interested in whether it’s possible to change their basic structure—not just simple adjustments like different shelves, but also modifications to the dimensions, depth, or even the material—without completely reinventing the system.
Has anyone had experience with how flexible PAX really is, especially when you want to meet more individual requirements than standard solutions allow?
Looking forward to your insights and experiences!
jordanvin12 Dec 2020 09:14Hey! That’s a really interesting question you’re raising! 😃
I’ve worked with PAX myself quite a bit and I think the system is a real winner among furniture systems. Of course, it wasn’t originally designed as a fully customized piece, but especially for DIY enthusiasts it offers great opportunities to add your own ideas.
For example, you can do a lot by swapping the doors or creating custom interior layouts. The dimensions are set by predefined frames, but with some craftsmanship you can also make adjustments—like adding frame profiles or modifying the back panels.
Go ahead and give it a try, it’s definitely worth experimenting a bit! Good luck! 💪
jordanvin schrieb:
You can do a lot, for example by replacing the doors or customizing the interior layout.That is certainly true, but I would cautiously point out that stability and load-bearing capacity can quickly become an issue with such modifications. The modules are designed for specific standard dimensions. Anyone who starts altering the frame without proper planning risks warping or even compromising the structural integrity.
The choice of materials is also not freely expandable. PAX mainly uses particleboard with melamine-coated surfaces, which brings certain limitations when it comes to DIY projects or replacement parts.
My question would therefore be: What is the main goal of these adjustments? Is it purely aesthetic, functional, or should the modules actually become more durable or customized through new materials?
Interesting discussion!
I see it a bit differently. Why shouldn’t the PAX system be adaptable for modified cabinet shapes or even completely different materials? Sometimes the standard system itself isn’t the problem, but rather the desire to modify it. I believe the appeal for DIY enthusiasts is exactly this breaking away from the norm.
Anyone who wants can extensively modify PAX – it just requires courage and willingness to experiment. Often, this leads to the most exciting custom creations that off-the-shelf products can never achieve.
So: There are always clear limits, but those who dare, win!
lise56 schrieb:
That is certainly true, but I would critically point out that stability and load-bearing capacity can quickly become an issue with such modifications.
It should be noted that PAX components are standardized. Adjustments to the depth or height can only be made to a limited extent without manufacturing additional parts.
The best solution is to use the system as a base and carry out any supplementary carpentry work yourself.
