ᐅ Is it possible to combine IKEA BESTA furniture with acrylic or glass elements?
Created on: 1 Apr 2024 09:17
Davin31Is it possible to combine Ikea Besta furniture with acrylic or glass to enhance its appearance or expand its functionality? Specifically, I am interested in whether sturdy glass or acrylic fronts can be attached to BESTA cabinets or shelves without weakening the original structure or limiting the functionality of doors and drawers. Does anyone have practical experience or advice on mounting, material selection, or important factors to consider when adding plexiglass or real glass to BESTA units? Are there compatible accessories, DIY solutions, or modifications that are recommended?
I can understand very well that you want to enhance your BESTA; I feel the same way. For me, it was important to have a lightweight option, which is why I chose acrylic, as it is less prone to breaking. It can be a bit tricky to secure it properly so that nothing rattles, but small silicone pads placed between the frame and the acrylic work quite well. However, you really need to pay close attention to the measurements to ensure the doors close properly.
Hey, the topic of acrylic versus glass for BESTA is really interesting! 😊 Some time ago, I replaced my shelves with acrylic sheets – they look very stylish and feel almost as elegant as real glass, but they are much lighter and more shatter-resistant. One tip: the edges of the acrylic sheets should be well deburred. Otherwise, you can treat them almost like regular glass, and the BESTA units look really great.
This can generally be done well – it is important to consider the load-bearing capacity of the doors, as glass and acrylic have different weights. Acrylic is lighter and therefore better suited for mounting on BESTA doors. If you want to use glass, make sure it is thin and tempered, and ideally mount it in a separate frame that is screwed onto the furniture. Avoid screwing directly onto the wooden surfaces without reinforcement, as this can cause stress.
Mufato schrieb:
Glass is only recommended with a frame, otherwise there is a risk of breakage. This is an important point that everyone should consider: glass requires a carefully designed framing system. Otherwise, the structural integrity can be compromised. It should not be forgotten that BESTA components are not designed for heavier glass panels – this can lead to damage over time. Additionally, there are hardly any official Ikea accessories intended for glass replacement, which means a custom solution with precise measurements is necessary.
