ᐅ Is there a way to change the color of IKEA Brimnes furniture without using paint?
Created on: 22 Dec 2022 18:37
fadytu44
fadytu44
22 Dec 2022 18:37
I am currently looking into ways to change the color of IKEA Brimnes furniture without using paint. It is important to me that the process remains as simple as possible and does not involve complicated painting techniques or toxic fumes. I am considering materials like films, fabrics, or other alternatives that can visually alter the surface without the need for paint or lacquer.
Does anyone have experience or ideas on how to permanently and attractively modify typical Brimnes furniture, which is usually made of particleboard with a coated surface? Are there specific products or technical tips that provide long-lasting results?
Thanks for sharing your advice!
DUVIN
22 Dec 2022 18:45
Hi,
try using furniture laminates or self-adhesive vinyl films. These are often specially designed for furniture surfaces and adhere well to smooth surfaces. They are also easy to remove if you no longer like the look.
GALEO4
22 Dec 2022 19:02
It's interesting that the discussion here immediately moves past paint. But honestly: Are films and similar coverings really a viable alternative, or are they more of a half-hearted solution?
Films can peel off, fabric covers don't always look high-quality, and especially for furniture that is frequently used, this is not a lasting way to increase value.
Maybe it’s better to just accept the standard instead of constantly searching for makeshift solutions that are hardly sustainable.
KARJU
22 Dec 2022 19:35
GALEO4 schrieb:
Are films and similar materials really a viable alternative, or is it more of a half-hearted solution?
Film can definitely be a practical solution, provided it is applied correctly and is of high quality. It is important to ensure that the surface of the Brimnes furniture is clean, free of grease, and as smooth as possible. Using a heat gun can often prevent or remove bubbles.
Alternatively, there are furniture films with special adhesives that are significantly more durable than cheaper options. These films are available in matte, glossy, or even textured finishes.
Fabric covers are more suitable for upholstered furniture rather than pieces with flat surfaces like cabinet doors or drawer fronts. In those cases, adhesion and everyday durability are limited.
In summary: Films offer a flexible and reversible solution that can often replace painting—provided you invest in quality and take care during application.
fadytu44
23 Dec 2022 10:14
KARJU schrieb:
Fabric coverings are more suitable for upholstered furniture, not for surfaces like cabinet doors or drawer fronts. In these cases, durability and everyday practicality are limited.
That’s a very good point, thank you! I asked the question because I was considering whether applying special furniture films or even a textile option might be useful.
Could you also share how removing such films compares to paintwork? Are there issues with residue or damage? This is an important factor for me regarding long-term use.
Does anyone have practical experience with this?
Surela
23 Dec 2022 12:57
Detailed response regarding surface alteration of Brimnes furniture without paint:
Brimnes furniture is typically made of white-coated particleboard, which significantly limits the options for modifying the surface. Essentially, you can consider the following approaches:
- Furniture films (self-adhesive): High-quality vinyl films adhere well to smooth surfaces. Careful preparation (cleaning, degreasing) and applying in a dust-free, warm environment are crucial. You can minimize air bubbles by using heat (hot air) and pressing firmly. When removing the film, adhesive residues may remain, which can be removed with gentle solvents like isopropanol and some patience, but the surface should not be damaged if handled carefully.
- Decoupage with special glue: Thin papers or fabric scraps are applied with special glue and then sealed. This is more experimental but offers a way to personalize without using paint.
- Contact paper / wallpaper: Generally thin and less durable but inexpensive. Durability and resistance are limited, especially under frequent use.
- Fabric covering: Works only to a limited extent and requires a rigid fixing in the end. It is rather impractical for drawer fronts.
Conclusion: Furniture film is the most straightforward and practical alternative to painting. Removing it is relatively low risk as long as aggressive solvents are avoided. Painting is somewhat more durable but also more labor-intensive and less easily reversible.
Do you have specific color preferences or particular usage scenarios?
One more tip: Use breathable materials, as particleboard can swell when exposed to moisture. Films and coatings with good flexibility are advantageous in this regard.
