ᐅ Is there a video tutorial that makes assembling the Ikea Brimnes easier?
Created on: 24 Jun 2015 08:17
Leisaias
Leisaias
24 Jun 2015 08:17
Hello everyone, I wanted to ask if anyone knows a good video tutorial that really makes assembling the Ikea Brimnes wardrobe easier. I have looked through the standard paper instructions, but I find them somewhat confusing at times, especially regarding the mounted side panels and the drawer mechanisms. A detailed video guide that shows step by step how to put the individual components together and what to pay special attention to would be very helpful for me. So if anyone can recommend a video that is well-structured and clear, I would really appreciate the tip. Thanks in advance!
Lenfa
24 Jun 2015 09:03
Leisaias schrieb:
I wanted to ask if anyone here knows a good video tutorial that really makes assembling the Ikea Brimnes wardrobe easier.
Hello, your question is very specific, and I’m glad about that because assembly videos can vary greatly in quality. Some time ago, I assembled the Brimnes myself and would recommend searching on YouTube for videos with a high number of positive ratings and comments. It’s helpful to look for videos that use clear camera angles and provide explanatory commentary. Often, videos from people who not only show the assembly process but also explain which parts need to be handled with extra care are especially useful.
The most important thing is to sort all the individual parts before starting and to have the screws, dowels, etc., ready according to the instructions. Do you already have experience assembling other Ikea furniture? If so, that will make things easier for you. If not, I’d be happy to share some basic tips as well.
PULAU
24 Jun 2015 13:22
Leisaias schrieb:
A detailed video tutorial that shows step by step how to assemble the individual components and highlights what to pay special attention to would be very helpful for me.
To answer clearly: Yes, such videos do exist, but the quality varies greatly. I would recommend watching videos that not only show the general assembly but also point out common mistakes. For example, it is important not to misalign the screw holes or to position the drawer slides precisely.
Videos filmed in a calm environment without time-lapse are also helpful, as they make it easier to follow along. If you haven’t found them yet, there are videos specifically covering the Brimnes wardrobe with drawers in several parts – these are often very practical.
Deoren
24 Jun 2015 14:37
Lenfa schrieb:
Sort all individual parts before assembly and have screws, anchors, etc. ready according to the instructions.
This is truly the most important tip. Without pre-sorted parts, you quickly create obstacles for yourself.
PULAU schrieb:
Align the drawer slides precisely
Exactly, this ensures smooth operation later on and prevents damage.
asete
25 Jun 2015 08:58
I like to go into more detail about the assembly process and can explain quite a bit on the topic. Regarding the Ikea Brimnes: assembling the side panels and especially the drawer mechanisms requires careful attention and can be much easier with the right instructions.
In the video, you should watch for whether the creator covers the following points:
- Sorting and checking all individual parts before starting
- Explanation of the connection methods, for example, how dowels and screws are joined
- The procedure for inserting the drawer slides and how to adjust them precisely
- Tips on common mistakes, such as twisting of the wooden panels or incorrect screws
It is often also helpful if the video shows how to correct errors—how to recognize that something is not fitting correctly and how to fix it.
My question to you: Have you already started or are you still at the very beginning? Do you have any additional information or details that are causing you problems during assembly? Sometimes questions arise when handling certain components.
PRA64
25 Jun 2015 12:11
I would like to add a brief written guide here that can be used alongside the video:
- Step 1: Sort all parts and check them against the included parts list.
- Step 2: Prepare your tools (Phillips screwdriver, possibly a hammer, and a cordless drill with torque control).
- Step 3: Attach the back panel first to ensure the frame is stable.
- Step 4: Screw on the side panels, making sure the dowel holes are correctly aligned.
- Step 5: Install the drawer slides very carefully; I recommend using a spirit level for this.
- Step 6: Assemble and insert the drawers.
A common mistake: The drawer rollers should not be tightened too much, or they may jam later.
If the video you have covers these points clearly, you will be well prepared.
