ᐅ Is there a trick to combining Kallax shelving units with underfloor heating?
Created on: 16 Apr 2024 18:37
rockyfo
rockyfo
16 Apr 2024 18:37
I recently installed an in-wall heating system in my living room. Now, I want to place a Kallax shelf unit from Ikea against that wall. However, the heat from the wall heater causes the wood of the shelf to discolor slightly and may eventually cause it to warp. My question is: Are there any tricks or proven solutions to safely and permanently combine a Kallax shelf with an in-wall heating system without damaging the shelf?
I have thought about installing some kind of heat shield behind the shelf or placing the shelf at a distance from the wall, but of course, an optimal and space-saving solution would be ideal.
What are your experiences or tips? Thanks in advance!
Dopoki
16 Apr 2024 19:52
Basically, a wall heating system poses a challenge for wooden shelves, as the material is quite sensitive to heat and the related fluctuations in humidity.
A practical solution is to install an insulating layer between the wall and the shelf. This could be a thin sheet of plastic or a heat-resistant insulation material that reduces direct heat transfer to the wood.
Additionally, keeping a small gap between the shelf and the wall is important to allow air circulation, which prevents heat buildup and excessive drying of the wood. A distance of 2-3 cm (about 1 inch) is usually sufficient.
I consider direct mounting of the Kallax shelf without any gap problematic. If it does not affect the appearance, a ventilated construction is the best way to avoid damage.
Josefane
17 Apr 2024 07:15
Dopoki schrieb:
In my opinion, mounting the Kallax shelf directly without any gap is problematic.
I agree with that, but I wonder if the heat input could also be set to a low level. Often, the energy flow is the key factor influencing how much the wood reacts.
Are there any precise measurements of how many degrees the shelf actually receives from the wall heating?
I think a combination of temperature limitation and distance would definitely be the best option.
Also, I wonder if certain surface treatments of the Kallax (e.g., sealing with heat-resistant varnish) could improve its durability. Does anyone have experience with this?
U
uslis47
17 Apr 2024 10:43
I would like to explain the topic in more detail, as I have already helped several times with wall heating systems and furniture facing similar challenges.
A Kallax shelf unit is made of particleboard, which is not very heat-resistant. Therefore, direct contact with a warmer surface can quickly cause deformation or discoloration.
The key points for a safe combination are:
1. Create a gap: Maintain at least 2 cm (1 inch) of air space, ideally 3-5 cm (1-2 inches), as convection improves heat dissipation.
2. Install a heat-insulating layer: A thin board made of Styrofoam or a similar lightweight insulation material works well. Please ensure it meets fire safety regulations.
3. Surface treatment: A heat-resistant coating or a special foil can help protect the shelf if it is already installed.
4. Monitor the wall heating temperature: Most wall heating systems allow continuous adjustment. Ideally, keep the wall surface temperature below 35°C (95°F) to prevent damage to the wood.
5. Ensure air circulation: Avoid placing the shelf too close to the wall and keep the back as open as possible.
In short: There is no patented “trick,” only a combination of good planning, spacing, and protection.
This should keep the Kallax shelf in good condition for a long time, even when the wall heating is running.
If you like, I can also recommend a few insulation products.
Elijah42
17 Apr 2024 12:31
In short: A gap is mandatory, at least 2 cm (1 inch). Additionally, use a thin insulation panel for thermal protection.
This is enough to prevent damage to the Kallax.
Direct contact is not advisable.
