ᐅ Is there a trick to assembling Ikea Brimnes furniture without the instruction manual?
Created on: 18 May 2022 08:13
Wassilijne
Hello everyone, I am facing a challenge assembling my Ikea Brimnes furniture without the included instruction manual. My question is: Are there any tricks, proven methods, or helpful tips specifically for the Brimnes series that can help assemble the pieces correctly and efficiently without the official guide? I am especially interested in advice regarding the typical sequence or any special characteristics of this furniture line, as I am impressed by the complexity and the large number of individual parts. Perhaps someone here has had similar experiences or knows of a general helper that makes the assembly easier. Thank you in advance for your feedback!
Espen schrieb:
Hinges usually help when aligning doors. Exactly, in addition, it is advisable to use the edges and drill holes of the side panels as a guide. This way, the basic structure can be quickly determined.
Wassilijne20 May 2022 08:52CHENFAR schrieb:
I also recommend assembling the furniture from bottom to top. That’s an interesting point, which helps ensure stability from the start. Can the bottom-up assembly method generally be considered standard for Brimnes furniture, or are there exceptions within this series? I ask because I’ve noticed that some cabinets, especially those with drawers, follow different assembly approaches, likely depending on the load distribution of the individual sections.
Wassilijne schrieb:
Can the principle of starting from the bottom and finishing at the top generally be considered standard for Brimnes furniture? By and large, yes. The construction usually starts with the bottom panel of the cabinet. Exceptions occur with small components like drawer slides, which are installed later. The main point is to make the basic framework stable first.
Wassilijne schrieb:
Is there any trick, a proven method, or helpful tips that can be specifically applied to Brimnes series furniture to assemble it correctly and efficiently without the official instruction manual? My tip: The numbering of drill holes and fittings at Ikea generally follows standard conventions. Try to match each part by its distinctive features, especially the base panels and backboards. This will save time.
