ᐅ Is there a trick to aligning Pax doors?
Created on: 21 Oct 2019 07:53
Luko34
Luko34
21 Oct 2019 07:53
Hello everyone, I have a question that keeps coming up while installing my Pax wardrobe doors: Is there a trick or a proven method to align the doors perfectly? I’m not just talking about rough adjustments, but really precise alignment so that the doors sit flush, don’t rub, and open smoothly. Especially with wider Pax wardrobes, I often find it difficult to align the doors because they seem to shift slightly even though I’ve tightened the screws properly. Is there a specific order for adjusting the hinges or a particular procedure I should follow? I’d appreciate any tips that can help me work cleanly and achieve a stable, long-lasting result.
PECLARISSA
21 Oct 2019 09:16
Hey Luko34, I know that all too well! 😊 My secret tip: first, loosely screw in all the doors, then align them step by step, and only tighten everything at the end. This way, you avoid any shifting when you start tightening the screws. And very important: be patient! Especially with taller or wider doors, it can sometimes be a bit fiddly. A small tip for that – make full use of the hinge mechanism by first adjusting the height, then the depth, and finally the lateral alignment. This way, you position the door exactly where it should be. If you do it like this, it will look more professional right away and you’ll enjoy it for a long time.
Lucki
21 Oct 2019 10:42
Exactly, PECLARISSA! I also had real trouble with my Pax doors at first, but once I tried your method, everything worked like a charm 😃 Adjusting them in the right order really makes a big difference! One extra tip: treat yourself to a right-angle screwdriver with a short handle. It lets you reach the hinges perfectly and adjust more precisely. Don’t get discouraged, keep at it! 😊💪
lofar
21 Oct 2019 11:37
Leave the hinges loose, align the door, then tighten. Follow the order: height, depth, width. Done.
kauti
21 Oct 2019 14:25
For aligning the Pax doors, I recommend the following procedure: - First, loosely install the doors and only hand-tighten the hinges - Then, adjust the vertical alignment (height) using the appropriate adjustment screws - Next, set the depth to align the door flush with the cabinet front - Finally, adjust the lateral alignment to ensure an even gap between the doors - Check that the doors open and close smoothly - Tighten all screws securely and check again It is important to follow this sequence to avoid unwanted shifts. Additionally, using a fine set of screwdrivers can save time by allowing precise handling of the screws.
Gilbert
22 Oct 2019 08:03
Interestingly, the supposed "problem" with Pax doors is often less about a specific trick and more about the construction method. The doors are designed to accommodate small tolerances, which means achieving a perfectly exact alignment is inherently difficult. In my opinion, the constant search for the "perfect" solution is somewhat overrated. It’s better to take a pragmatic approach: making slight adjustments after a few weeks can be useful, as the doors do tend to settle a bit. If you get too fixated on it, you can quickly lose enjoyment in the project.
