ᐅ Is there a specific type of screw required for the IKEA BRIMNES back panels?
Created on: 1 Jan 2022 10:37
Nicknon
Nicknon
1 Jan 2022 10:37
I have a question that has been on my mind for a while: Is there a specific type of screw intended for the back panels of the IKEA Brimnes wardrobe?
While assembling it, I noticed that the back panels are made of fairly thin material, and I’m wondering if there is a particular screw that is better suited to minimize the risk of tearing or damage.
I’m especially interested in whether IKEA provides its own screws for this, which differ from standard wood screws or similar, or if any screw of the right length and diameter can generally be used.
Does anyone have experience with this, or perhaps tips on which screws work best or if there are recommended types (for example, flat head, countersunk, specific thread) to use?
Thanks in advance for your help!
Mufato
1 Jan 2022 12:04
There is no special type of screw specifically for the BRIMNES back panels.
IKEA often uses regular nails or thin countersunk screws.
It is important that the screws are not too thick to avoid tearing the thin material.
For replacements, simply use thin wood screws (approximately 3mm diameter) with a long thread.
Luciandi
2 Jan 2022 16:59
I agree with that. Especially when rebuilding something yourself or replacing a back panel, it’s not always easy to judge. I was initially worried about overtightening and damaging the wood with my BRIMNES wardrobe.
Therefore, I would also recommend using the original parts if they are still available. Otherwise, thin screws with a countersunk head work well because they sit flush and don’t stick out too much.
It would be helpful if IKEA communicated this more clearly, especially for people who want to use or repair furniture for a longer time.
Maybe others here have experience with replacing screws or trying alternative options?
Rodolfo
3 Jan 2022 09:21
Regarding the screws for BRIMNES back panels, the following can be said:
- IKEA generally uses thin wood or furniture screws with a countersunk head, typically around 3x16 mm (1/8x5/8 inches) to 3x20 mm (1/8x3/4 inches), depending on the specific model year.
- The back panel material is thin wood particleboard, so care should be taken to avoid splitting.
- The screws are not specially patented or unique but are standard furniture screws suitable in length and diameter.
- When replacing, screws with the same dimensions are recommended, preferably with full threading for better grip.
Conclusion: There is no special type of screw for the BRIMNES back panel. Using standard furniture screws with matching dimensions is sufficient and common practice.
