ᐅ Is there a specific assembly guide for the IKEA BRIMNES chest of drawers?
Created on: 13 Oct 2020 09:07
O
OnsefuHello everyone,
I am currently facing the task of assembling an IKEA Brimnes chest of drawers and wanted to ask: Is there a special assembly guide for the BRIMNES chest that differs significantly from the usual furniture assembly instructions provided by IKEA?
I am asking specifically because I have heard that some IKEA models have unique features or additional steps that are not immediately obvious. It would be helpful to know if I should look out for a separate set of assembly steps or if the standard instructions are sufficient.
By now, I am also a bit confused about whether certain tools or sequences are recommended that are not included in the normal booklet.
I would appreciate any experiences and tips from you on how to best approach assembling this chest, especially if there is a special document or list provided by IKEA for the BRIMNES.
Thank you in advance!
The IKEA BRIMNES chest of drawers comes with a small illustrated manual.
This manual is complete and specific for the standard assembly. There is no separate additional document.
Tools: A screwdriver and possibly a hammer are usually sufficient.
Simply follow the included instructions step by step.
Hello Onsefu,
I can understand your question well, as some IKEA furniture can indeed have its tricky points.
Regarding the BRIMNES dresser: IKEA always provides a very detailed instruction manual specifically tailored to the furniture item. There is no separate or "special" additional guide. The manual covers all important steps from assembling the frame to installing the drawers.
What I would recommend is to read the entire instruction manual carefully before starting assembly. Even if it seems obvious to you, this will help avoid unnecessary mistakes and allow you to better understand how the parts are numbered or which order of steps makes the most sense.
Additionally, it can be helpful to sort all parts completely and check that everything is included before beginning assembly.
If you feel unsure about any steps or encounter unclear instructions in the manual, you will get prompt help here on the forum.
I wish you the best of luck with your project!
I would like to provide a more detailed explanation regarding the IKEA BRIMNES chest of drawers and its assembly instructions since I have assembled several versions of the BRIMNES myself.
First, regarding the question about a special manual: IKEA actually provides only one standardized instruction sheet for the BRIMNES chest of drawers, which is included in the package. From my experience, this manual is very clear and covers all the necessary steps. There is no separate document with extended notes or alternative assembly methods.
It is important to keep the following points in mind:
- Preparation of all parts: Check all wooden components, screws, and additional parts against the included parts list.
- Follow the sequence carefully, as some steps are difficult or impossible to complete without previous assemblies (for example, fully assembling the carcass before inserting the drawers).
- Use the correct tools – usually, a Phillips screwdriver is essential, and a hammer for tapping in dowels.
- Common mistake: Over-tightening screws, which can damage the panels. It’s better to tighten them firmly by hand but not fully tightened.
The answer here is clear: No, such a special instruction does not exist, but the supplied manual is good enough to manage without additional information.
If you’re still unsure, I can gladly provide a short step-by-step guide that I created for myself during assembly. Just let me know!
Best regards!
Onsefu schrieb:
Is there a special instruction from IKEA for assembling the BRIMNES chest of drawers that fundamentally differs from the usual furniture assembly manuals?
Best regards!
Interesting thread here. It might be worth considering what is actually meant by "special instructions."
Isn't a special instruction usually just a more detailed version or a clearer presentation of the standard IKEA documentation? There is no secret manual or legally binding standard for such furniture, but rather a practical step-by-step guide.
This is crucial. For some users, even the IKEA instructions could be improved in certain areas. But waiting for a "special" instruction that explains more complex situations better might just postpone the real issue, which is to raise users to a higher level of understanding.
So it’s better to read through once more, check carefully, and ask precise questions if there are any doubts.
It would be interesting to know if there are actually any objections to specific points that are not covered in the IKEA instructions. Those could possibly be collected systematically in the forum.
angel schrieb:
What I would recommend is to read the instructions carefully before assembly.
