ᐅ Is there an easy way to adjust IKEA BESTA doors?
Created on: 26 Jul 2024 08:37
eleakla
Hello everyone, I installed the doors on an IKEA Besta cabinet, but unfortunately the door panels don’t fit perfectly. They are slightly misaligned and sometimes don’t sit flush. My specific question is: Is there a simple and practical way to adjust the doors on IKEA Besta units so that they are perfectly aligned again? I am interested in suitable tools as well as possible adjustment mechanisms on the hinges or fittings that can be used quickly and easily in everyday situations. Does anyone have practical experience or tips that go beyond just tightening or loosening screws? Thanks in advance!
eleakla
27 Jul 2024 09:12
KNUTGI schrieb:
My tip: If you notice a screw won’t turn – don’t force it, or you’ll make it worse.
Thank you for this advice, that was also my concern. Some of the screws seem quite tight. How much force is safe to apply without causing damage? Are there any tips for loosening stuck screws without harming the material or surface? Does anyone have experience with lubricants or similar products that can be used safely?
Nabla64
28 Jul 2024 16:38
eleakla schrieb:
Are there any experiences here with lubricants or similar products that can be used without concern?
Generally, plastic and metal parts in IKEA furniture are designed in a way that they can become a bit stiff over time. For the hinges on Besta doors, I recommend a dry lubricant such as silicone spray or a special graphite powder, as these are non-sticky and do not attract dust.
Important: Do not use WD-40 or oil directly, as these can damage plastic components or cause dirt buildup. Always test a small amount in an inconspicuous area before applying.
When tightening – the screws should turn smoothly with normal force using a screwdriver. If they stick, you can try slightly loosening the screw and gently moving the mechanism to help the parts realign. Repeated gentle movement is better than applying excessive force.
Summary:
- Use dry lubricants
- Avoid oily or sticky substances
- Handle screws carefully, do not overtighten
If you want more details about the exact screw positions, I’m happy to explain.
