ᐅ Is there a protective film available for MALM surfaces?
Created on: 17 Dec 2021 09:43
Soron8
Soron8
17 Dec 2021 09:43
I’m planning to buy a new MALM bed from IKEA, but I’ve already heard from several people that the painted surfaces are quite prone to scratches, wear marks, and generally quite delicate. Therefore, I want to ask if there is a special protective film on the market for MALM surfaces that can protect them from mechanical damage without significantly changing the appearance or feel.
It is important to me that the film can be removed without leaving any residue, does not cause discoloration, and, if possible, is available in a precise fit for the MALM series. If anyone has experience with such protective films or alternative solutions, I would appreciate a detailed assessment.
Best regards!
Hannes
17 Dec 2021 10:11
As far as I know, there is no IKEA-specific protective film for MALM. However, you can use simple transparent protective films designed for furniture or display protection. Just cut them to size and apply. Make sure the surface is completely clean and dust-free.
sarlo
17 Dec 2021 15:29
Hello Soron8,
I completely understand your concern, as the MALM surfaces, especially the painted versions, are quite delicate. Using a protective film is generally possible – many people use clear films designed for tabletops to prevent scratches or stains.
Hannes schrieb:
"There is no IKEA-specific protective film for MALM"
That is correct; IKEA does not sell anything specifically for this purpose. However, there are various films available at hardware stores or online that work well. It is important that the film is either adhesive-free or has a removable adhesive that leaves no residue, otherwise you risk damaging the finish.
I would recommend measuring the surface before purchasing and maybe trying a more affordable option first. Sometimes special UV-resistant films are recommended, as the material can yellow over time. Please feel free to share your experience once you have made your decision.
Best regards!
letar
18 Dec 2021 08:07
Additional Information:
There are protective films made from polyurethane (PU) or PET commonly used for furniture and electronic devices. These films offer good abrasion resistance and can usually be removed without leaving any residue. For MALM surfaces, I recommend a film thickness between 50 and 100 micrometers to provide sufficient protection without causing visible or tactile changes.
One challenge is achieving an exact fit. Since MALM tables and shelves come in different dimensions, it makes sense to either purchase films in standard sizes and cut them precisely or look for custom-made options from suppliers.
Important: Before applying a film, the surface should be thoroughly cleaned and degreased to ensure optimal adhesion and a bubble-free finish.
Conclusion: There is no protective film specifically designed for MALM surfaces available on the market, but high-quality, universally applicable furniture protective films are suitable if attention is paid to material quality, thickness, and careful application.
