ᐅ Is there a hair strainer or hair trap available for linear shower drains?
Created on: 7 Jul 2021 22:43
KatdreasHello,
The drain in our shower is already starting to weaken, and we have only been living in the house for 15 months.
We have a linear shower drain from Geberit. The cover is regularly removed, and some hair always gets caught on the black plastic prongs. However, I’m afraid that a lot of hair is passing through and now clogging the pipe. I have ordered a professional product (PEIP F drain cleaner) to fix this. Hopefully, it works!
Is there an additional hair strainer that can be used with linear shower drains? I haven’t really found anything on this. I would like to take preventive measures in the future.
Thank you and best regards
Bertram1008 Jul 2021 08:42Professional drain cleaners are rubbish. DIY drain cleaning products are no better and not exactly environmentally friendly. It’s better to use a pressure blaster or a drain snake if possible. It only takes about a minute. The initial cost is roughly the same as drain cleaner (around 8 euros).
I have long hair and know the problem well. That’s why I specifically opted for a “normal” drain so I can occasionally just use a plunger. Done.
Bertram100 schrieb:
Professional drain chemicals are rubbish. DIY drain cleaners are no better. They’re also not environmentally friendly. It’s better to use a pressure bladder or a drain snake if possible. It only takes about a minute. The initial cost is roughly the same as drain cleaner (around 8 euros).
I have long hair and understand the problem. That’s why I specifically chose a “standard” drain so I can occasionally clear it easily with a plunger. Done. I now have a shower channel drain... no idea how a drain snake would work with that.
Bertram1008 Jul 2021 08:49Apparently, that is possible, or so I've heard. But how exactly, I don't know either.
hanghaus20008 Jul 2021 09:36I would simply pull a nylon stocking over the cover. Done.
