ᐅ Is there a guide on how to use Ikea BESTA units for installing a beverage fridge?
Created on: 5 Apr 2020 19:17
blakedaHello everyone, I am planning to use some Ikea BESTÅ units as built-in frames for a beverage cooler. My question is: Is there a detailed and tested guide on how to best use Ikea BESTÅ modules as built-in enclosures for standard commercial beverage coolers? I am imagining a setup that makes optimal use of the available space while ensuring sufficient ventilation and addressing safety concerns. If anyone has experience with this type of conversion or useful tips regarding stability, fastening, and possibly integrating the cooler door with the BESTÅ fronts, I would greatly appreciate it. Any advice on potential challenges or hidden issues when using BESTÅ as a built-in beverage cooler enclosure would also be very helpful.
praWarre695 Apr 2020 19:46Hey blakeda, cool plan! 😎 I don’t have a finished building plan, but from experience I can say: BESTÅ is very flexible, even though there’s no specific built-in design for refrigerators. It’s important to allow enough airflow around it, otherwise the fridge will heat up and cooling performance will suffer. Tip: open the back panel of the BESTÅ or install ventilation grilles. Also, many compact refrigerators fit quite well into the module sizes, especially the 60cm (24 inches) widths. You can often attach the door to the front with magnetic tape to make it look seamless. If you’re handy, you can also add wooden strips as an inner frame to keep the fridge stable. Good luck and keep us updated!
Genevieve5 Apr 2020 20:12I find the question interesting but also more complex than it initially appears. Basically, IKEA BESTÅ is not designed for technical appliances like refrigerators, which means, for example, there are no pre-made ventilation channels or heat-resistant materials. Additionally, the question arises whether the weight and vibrations of a running beverage refrigerator can safely be transferred to the construction.
I would like to know more: Which refrigerator models are specifically being considered? Are there dimensions and technical specifications available? And how is the electrical connection and heat dissipation planned to be ensured within the built-in cabinet?
Without these details, any instructions would be more of a rough guideline—and not necessarily a guarantee for success. Therefore, I question whether BESTÅ is truly the best choice, or if it might be better to use other furniture or construction options.
Genevieve schrieb:
I therefore question whether BESTÅ is truly the optimal choice, or if it would be better to consider other furniture or construction options.I completely agree! IKEA furniture is more designed for decorative purposes or light household items, not as an enclosure for active cooling equipment. The heat dissipation is often underestimated, and if you’re not careful, you can quickly get heat buildup that will damage the compressor. Just because it fits doesn’t mean it’s practical. Sometimes the quirky IKEA look is simply too much of a compromise.
praWarre69 schrieb:
It’s important to allow enough air circulation all around; otherwise, the refrigerator will overheat and cooling performance will suffer.Exactly, and there’s even a risk of mold if air can’t flow in and out. The built-in spaces in real kitchen cabinets are much better designed for this, even if they’re less trendy.
I can understand both sides. The idea of customizing Ikea BESTÅ to create something unique is appealing because it results in a personalized piece. However, I also see how quickly small issues like insufficient ventilation or tight fittings can cause problems. I believe it’s important for blakeda, if possible, to precisely measure the fridge—not only the installation dimensions but also to consider the operating conditions. Additionally, I would recommend allowing a bit more space to avoid potential stress on the appliance and to prevent issues like noise or excessive running times. Usually, people don’t just have one fridge; they also appreciate when it provides reliable service over a long time.
