ᐅ Is there a guide for easily converting IKEA BESTA units into a TV and media furniture?
Created on: 12 Jul 2022 08:23
emmett35
Hello everyone, I am considering modifying my IKEA Besta furniture piece into a TV and media unit. My specific question is: Is there a clear, preferably simple and step-by-step guide on how to modify the BESTA system to include cable management, create space for consoles and receivers, and possibly even install a sturdy mount for the TV? It is important to me that the steps are manageable for a layperson without the need for expensive special tools or advanced woodworking skills. Does anyone have experience with this or know of a guide on how to approach it? Thank you very much in advance!
BOLUKEO
12 Jul 2022 13:55
Buy wooden board, remove back panel, screw board in place, attach TV mount. Drill cable entry holes on top or at the back.
Cecilera66
13 Jul 2022 07:22
I just did this myself. Tip: Use cable ducts or clips that stick to the inside of the side walls. This keeps the cables organized. For the TV mount: The plywood sheet is invaluable. Pre-drill, insert anchors, and the mount will hold perfectly.
dosogau
13 Jul 2022 09:38
If stability is important to you, I recommend using a glued laminated timber board instead of the back panel. The back panel is often just a thin chipboard, which does not support the TV mount well. Cable grommets from the hardware store are very practical.
islaron
14 Jul 2022 10:15
On the topic of instructions: There are many DIY videos available online, but no official IKEA manuals for this kind of conversion. My recommendation: Draw your furniture layout, plan where appliances will go, and carefully measure cable routes. This will help you avoid mistakes during the conversion.
COLEBAR
14 Jul 2022 12:42
I drilled a cable entry hole in my Besta and mounted a bracket behind a reinforced rear panel. It is important to choose the right drill bit size, as cables do not look good when squeezed through the openings.
