frankmehlhop12 Aug 2020 15:27Hello,
is there a type of pipe that does not burst or get damaged when the water inside freezes due to low outside temperatures?
(e.g., composite pipe with screw fittings, PE with adhesive fittings, HDPE pipe)
Frank
Frank
nordanney12 Aug 2020 15:53No idea, but I doubt you can get any kind of warranty on that anywhere. The 10% expansion of frozen water will always eventually win against the pipe or at least the connections. Nature always wins!
Maybe a continuous steel pipe with a 10mm (0.4 inch) wall thickness.
frankmehlhop12 Aug 2020 22:11Tassimat schrieb:
There are frost-proof outdoor water taps. They work because the pipe length is short and one end is open. But a whole pipe? What are you planning to do?I want to install a water pipe in my house for non-potable water. In winter, there could also be frost inside the house (poorly insulated, unoccupied for an extended period).
