ᐅ Is there a difference between older and newer IKEA PLATSA models?
Created on: 11 Jan 2022 09:17
jannisli54
I am considering getting an IKEA Platsa system, but I have noticed that there are now different models that seem to vary in design and construction. My question is: Is there a significant difference between the older PLATSA models, which have been available for several years, and the newer versions currently in the range?
I would especially appreciate a comparison regarding material quality, connectors, modularity, and any changes in the assembly principle. I want to make sure I buy a durable product that can also be expanded or adjusted if needed.
Does anyone have experience or know the technical differences between the versions? Thanks in advance!
jannisli54
11 Jan 2022 15:37
Thanks for your responses so far, they have been very helpful. I have one more question: Does anyone have experience with the long-term stability, especially whether the new connections remain as stable after months or years as they are initially?
I have sometimes noticed with older IKEA furniture that screws loosen or joints become wobbly, which makes me a bit uncertain about Platsa, since the system is modular and partly designed to be transportable.
Meoru
12 Jan 2022 09:11
In my experience, the new models do not tend to loosen. The clips and connectors are designed so that they do not expand or loosen through normal use. Of course, regularly retightening the screws helps, but this is needed much less often with the newer versions. I would say the long-term stability is better than with the older models.
jordanvin
12 Jan 2022 11:04
I have been using my new PLATSA parts for almost a year now and I’m really impressed! Everything holds up great, no loose connections, and even when rearranging, you can tell the connectors are sturdy. For me, this is a clear improvement compared to older IKEA furniture. Simply excellent! 🙂
kemads46
12 Jan 2022 14:50
jannisli54 schrieb:
I sometimes notice that screws loosen or connections become wobbly in older IKEA furniture
This is a common issue with furniture that uses screw-based assembly systems and is not limited to PLATSA. However, newer PLATSA models include additional safeguards, such as rubber buffers or special nuts, to prevent loosening.
My tip:
- Check the connections after about 6 months and tighten them if necessary
- Avoid overloading the units, especially wall-mounted cabinets
This prevents most problems. The PLATSA system is quite durable when handled properly.
