ᐅ Is there a colored alternative to the classic Ikea BRIMNES furniture?
Created on: 24 May 2020 09:23
Henry1
Henry1
24 May 2020 09:23
I recently looked at some Ikea Brimnes furniture and especially appreciate the clean design and functionality. However, I’m not very fond of the classic color options like white or black-brown, as I would prefer colorful furniture pieces to make my living space feel more lively. My specific question is: Are there any colorful alternatives to the classic Ikea BRIMNES furniture?
By that, I mean furniture with similar construction, dimensions, and functionality, but available in fresh color options. It would be great if you could offer tips on manufacturers or models that go in this direction. I’m also interested in information about modification possibilities or paint finishes that have proven effective.
Thank you in advance for your help!
Traman4
24 May 2020 09:45
Hi,
I am not aware of colored BRIMNES alternatives in the exact same style. You could look for similar modular systems from other manufacturers or paint the IKEA furniture yourself. That way, you get the color you want with the same base model.
RETRAVIS
24 May 2020 10:12
Regarding the question about a colored alternative to Ikea BRIMNES furniture, here are the facts:
- BRIMNES is a very classic system with clean lines and MDF fronts, usually laminated or painted in white or black-brown.
- Other manufacturers offer similar furniture with colored finishes, but usually not with exactly the same dimensions or mechanisms.
- IKEA itself does not offer colored versions of the BRIMNES range.
- To achieve a colored option, painting or wrapping services are the most affordable and flexible solutions.
If the furniture functionality and construction should be similar, customizing the IKEA models yourself is usually the most practical solution.
angel
24 May 2020 11:03
Hello Henry,
I understand that you’re looking for some color, as the BRIMNES furniture is quite neutral. Here are a few suggestions you could try:
- Although IKEA doesn’t offer BRIMNES in colored finishes, other series have colored fronts (e.g., METOD kitchen or BESTÅ in colored versions), so it might be possible to combine or modify these.
- If you have some DIY skills or know someone experienced with paints, you could repaint the furniture yourself. Proper preparation with sanding and suitable primer is essential here.
- For furniture that isn’t painted but laminated, using a colored vinyl wrap can be a practical alternative.
If you like, I can also share some tips on what to consider when repainting to achieve a good result.
TYRELL
25 May 2020 08:37
Hello Henry,
regarding your question about a colored alternative to the classic Ikea BRIMNES furniture, I would like to go into more detail.
First of all: BRIMNES is mainly characterized by its sturdy construction made of particleboard with a melamine resin coating and a relatively simple design with clean edges. The dimensions and drawers are optimized for maximum storage capacity in a compact format.
Unfortunately, IKEA does not offer colored variations, which presents a challenge for many users who want to add color. Other manufacturers offer furniture with similar functionality in the low-budget range, but dimensions, build quality, or design usually differ.
If you want a colored alternative, some options are:
- Choosing a similar furniture system from brands like Roller, Poco, or retailer own brands, which sometimes offer colored surfaces or decorative finishes.
- Considering furniture in modular systems with interchangeable fronts available in bright colors.
- Modifying or repainting your BRIMNES furniture. It is important here that the surface, which is often laminated on BRIMNES, is thoroughly sanded first and treated with a suitable adhesion primer before applying a durable paint in the desired color.
A downside of a complete new purchase of colored alternatives is often the price-performance ratio. Therefore, depending on your DIY skills, I would recommend either repainting or professional wrapping.
I would be interested to know whether you prefer to paint furniture yourself or are looking for a ready-made solution?
ritotar
25 May 2020 12:21
Hello Henry,
I really like how precisely you phrased your question! Colored furniture truly brings life to a room.
As a simple alternative, I’ve tried this: you get inexpensive white IKEA furniture (e.g., BRIMNES) and customize it with colored adhesive films or furniture markers. It’s quick, looks fresh, and can be reversed at any time.
The big advantage is that you can choose not only the color but also add patterns or small accents—without much painting effort.
Of course, it’s not an original colored piece of furniture, but sometimes a bit of creativity is enough to add beautiful splashes of color to the room.
Maybe this could be something for you if you’re interested in a DIY project? You start with white and can customize everything individually.
