Hello everyone, I have just started planning with IKEA Besta shelving systems because we want to create a child-friendly storage solution for our apartment. I am wondering if there is a child-friendly version of IKEA Besta that is specifically designed to meet the needs of families with young children. My main concerns are that the furniture is safe, sturdy, and as flexible as possible to adapt to changing uses. Additionally, I am interested to know if there are child-appropriate designs, rounded edges, or suitable inserts to make the system as child-friendly as possible. I would appreciate any detailed information, experiences, or practical tips on how to make the Besta system more “child-friendly.”
Hello Kigla, your question is very relevant because with furniture like Besta, which tends to be modern and minimalist, child safety is often not the main focus. As far as I know, there is no “child-friendly version” in the direct sense from IKEA – meaning there are no specially certified Besta modules with rounded edges or built-in safety features specifically designed for children.
What you can do to make the system more child-friendly and safer:
- Cover edges and corners with edge guards made of soft plastic or felt (available as accessories at hardware stores or online)
- Use furniture anchors to secure the furniture to the wall to prevent tipping
- Choose doors made of wood or plastic instead of glass doors to avoid injury risks from fragile elements
- Use interior fittings like boxes and baskets that have no sharp edges
You already have flexibility thanks to the modular design. It is certain that with some simple additions, you can make the whole setup much more child-friendly. If you like, I can also provide examples of alternatives if you need to meet specific safety standards.
FeAndreas122 Aug 2022 13:52Naomige schrieb:
To my knowledge, IKEA does not offer a “child-friendly version” in the direct sense—that is, there are no specially certified Besta modules with rounded edges or built-in safety features explicitly designed for children.I can confirm that, but let’s look at it from a more technical perspective: Besta is a modular system with rather sharp edges and, in some cases, heavy fronts. The key safety aspect is securing it firmly to the wall (IKEA provides screws and brackets for this, but these should definitely be replaced with stronger, more secure ones, especially if you have young children) and using edge protectors or corner guards, which are quite easy to install.
You might also consider replacing glass fronts with wood or lacquered panels to eliminate the risk of glass breakage. For the interior, I recommend using sturdy storage boxes made of soft materials or fabric to reduce the risk of injury.
What makes Besta particularly flexible are the various heights and widths available: the lower versions are safer for smaller children because they are easier to reach and less likely to encourage climbing. From my point of view, the combination of secure mounting, padding on edges, and choosing appropriate dimensions is what really makes the system child-friendly.
Feel free to mention your children’s ages if you like, and I can offer more targeted advice on how to integrate Besta into your living situation.
FeAndreas1 schrieb:
You can also mention how old your children are, so I can give more specific advice on how to integrate Besta into your living situation.Thank you for your detailed reply! My children are 3 and 6 years old, both still very active. It is especially important to me that I can place the shelving unit in the living room, where they play a lot, without much risk. So I would prefer not too tall units, rather low cabinets that they won’t want to climb on or that pose minimal risk of injury. Also, having doors with smooth-operating and childproof locks would be beneficial.
The option with corner protectors seems reasonable. Are there installation-friendly solutions available that can be integrated without significantly affecting the appearance? Additionally, I’m interested in how the Besta fronts hold up in terms of durability with a small, energetic child.
warrenka5723 Aug 2022 09:37Kigla schrieb:
It is especially important to me that I can set up the shelf in the living room, where they play a lot, without significant risk.I can understand you well, especially when children play and romp around a lot. I had a similar experience with my two. What we found is that in addition to edge protectors, regularly checking the fixtures is very important. There is always a risk of accidents, especially when children pull themselves up on or try to climb furniture.
What helps: child safety locks can prevent children from accessing dangerous items in cabinets, but these locks can sometimes be a bit inconvenient for adults to use.
A tip from me: also consider the interior design, whether you can include lightweight bins and toy boxes that can be easily removed. This makes the shelf not only safe but also practical for the children.
If the shelf has solid doors, magnetic catches or child safety locks from third-party suppliers are also a good option.
As additional information: IKEA Besta furniture is not specifically designed with child safety in mind by default. However, its modular system offers certain advantages for families.
- The sharp edges and the weight of the fronts can be problematic, as they might tip over if not properly secured.
- Wall mounting is mandatory according to the manufacturer’s instructions. Child safety-optimized fastenings should be implemented using suitable anchors and screws that match the wall material.
- For edge protection, special transparent plastic profiles or foam pads are suitable, which can be attached to corners and edges.
- Child safety locks can be mounted externally, but they are not included as standard components of Besta.
In summary: A child-friendly version is achieved through a combination of secure anchoring, edge protection, and child-appropriate inserts. There is no official child-safe version offered by IKEA.
