ᐅ Is there a better way to assemble the IKEA Brimnes furniture without using the instruction manual?
Created on: 22 Apr 2016 07:23
thorsten7
Hello everyone, I am currently facing the challenge of assembling my new IKEA Brimnes wardrobe. I wonder if there is a better way to put together the Brimnes wardrobe without the original IKEA instructions, without risking mistakes or wasting too much time. The Brimnes has quite a few screws and flaps, and I’m unsure if there might be a method that has become established, which works faster or more intuitively, perhaps through alternative approaches or the use of specific tools. Has anyone had experience assembling this wardrobe fairly easily and efficiently without the instructions? I would greatly appreciate any specific tips, advice, or personal experiences.
A completely 'better' method without instructions is not recommended. The IKEA assembly manual is designed to minimize the risk of assembly errors and to structure the sequence of steps in an optimal way.
Experienced furniture assemblers may be able to perform certain steps more quickly and intuitively. However, for the vast majority, the manual remains the most efficient method.
Alternatively, if time is limited or there is uncertainty, you can:
- Use professional assembly services
- Refer to step-by-step video tutorials as a supplement
Using your own method without instructions carries the risk of placing screws in the wrong locations and potentially damaging the entire cabinet.
PIDAN schrieb:
The assembly instructions from IKEA are designed to minimize the risk of assembly errors and to ideally structure the order of the work steps. I have to agree with you there. Still, sometimes the instructions catch you off guard when you’re cold and you think, “Wouldn’t it be nicer if assembling was a bit more fun?”
I believe that if you approach the Brimnes with patience and a clear system, you can even get started without the original instructions by improvising a little. What’s important is to mentally prepare yourself for the assembly in advance and stay focused.
I have even tried a kind of ‘mental mapping’ where you basically check how the parts have to fit together, and surprisingly, it worked quite well. Of course, an instruction manual remains the best companion, but a bit of creative problem-solving can also make the process more enjoyable.
