ᐅ Is it advisable to use IKEA BRIMNES furniture in rental apartments?
Created on: 5 Apr 2020 19:12
Emelibar
I am moving into a new rental apartment soon and am considering whether IKEA Brimnes furniture, especially their wardrobes and beds, is a good choice. I am mainly concerned about whether these pieces are suitable for rental properties in terms of their construction, materials, and weight—for example, potential damage to floors or walls that could cause issues when moving out. I’m also interested in their stability and durability for everyday use in a rental, as I don’t want to replace them every year.
Has anyone had experience with this? Are BRIMNES furniture pieces suitable for rental apartments, or are there disadvantages related to their particleboard-based construction or other factors that I should consider? Tips on care and assembly are also welcome.
Thanks in advance!
Julien
7 Apr 2020 08:24
Hello Emelibar,
I would like to add a few basic tips regarding Brimnes furniture for a rental apartment that are often overlooked:
- Placement in the room: Especially for furniture with back panels or bottoms, make sure they are not placed directly against damp exterior walls to prevent mold or swelling of the particleboard.
- Protection against floor damage: Felt pads or foam rubber strips under the feet effectively protect the floor. This is particularly important for parquet or laminate flooring.
- Assembly: Use a cordless drill with adjustable torque when assembling to avoid over-tightening screws and damaging the material.
- Care: Melamine-coated surfaces are relatively easy to maintain, but avoid using harsh cleaning agents to prevent damaging the surface.
In summary, BRIMNES is a practical furniture series for rental apartments if these precautions are taken. For heavy use or long-term investments in solid wood quality, other series would be more suitable.
If you need help with proper assembly or care, I am happy to assist.
naujon
7 Apr 2020 12:30
Regarding the suitability of IKEA BRIMNES for rental apartments, I would like to provide a structured response:
1. Material and Stability
- The BRIMNES series mainly uses particleboard with a melamine coating.
- The furniture is lightweight, which makes moving easier.
- Load capacity is sufficient for everyday use but not designed for heavy, continuous loads.
2. Assembly and Disassembly
- Screws and dowels provide stable support but can loosen with repeated assembly and disassembly.
- Handle carefully to avoid enlarging the holes.
3. Protection of the Rental Property
- Felt pads under the furniture legs are essential to protect flooring materials.
- Back panels should not be placed directly against walls exposed to moisture.
4. Maintenance and Aging
- Melamine coatings are easy to maintain but prone to superficial scratches.
- Avoid moisture, as particleboard can swell.
Conclusion:
BRIMNES furniture is well suited for rental apartments if assembly, maintenance, and floor protection are taken into account. Precise documentation of the fixtures makes moving out easier.
If you need more information about specific pieces from the series, feel free to ask.
JULIANNALO
8 Apr 2020 09:41
Emelibar schrieb:
Has anyone had experience with this? Are BRIMNES furniture pieces suitable for rental apartments, or are there disadvantages I should consider due to the particleboard construction or other factors?
Yes, BRIMNES is well suited for rental apartments. The furniture is relatively lightweight and easy to assemble and disassemble. However, be careful with moisture and always use felt pads underneath.
