ᐅ Is it also possible to assemble IKEA Metod kitchens yourself for U-shaped layouts?
Created on: 28 Oct 2020 08:17
pasau
I am currently planning my new kitchen and am researching the IKEA Metod system in detail. My kitchen will have a U-shape, and I’m wondering if assembling the Metod system myself is straightforward with this layout.
I understand that IKEA primarily facilitates straight kitchen units, but how does the system handle a U-shaped configuration? Are the angles and corner solutions in the Metod system flexible enough to allow for the modules to be self-assembled and adjusted?
Perhaps some of you have experience building a U-shaped kitchen and can share whether the self-assembly is more complex compared to other layouts, and if there are any specific challenges or traps to watch out for during the installation.
I would appreciate any tips, experiences, or advice regarding suitable connectors or necessary adjustments!
pasau
29 Oct 2020 08:28
BOSULE schrieb:
It is important to align the cabinets on a level surface and securely fix all connection points.
That makes sense. Thanks!
Has anyone had experience with countertops? Since a U-shape is not easy to replicate on a countertop, I’ve heard that many kitchen planners have the countertop cut on site.
Does that fit well with the DIY approach, or is it better to hire a professional for the countertops?
Donar34
29 Oct 2020 09:16
For the countertop in a U-shaped IKEA Metod kitchen, professional cutting is highly recommended.
The materials—usually laminate, solid wood, or ceramic—require specialized tools and techniques to achieve clean and precise edges.
A countertop that is not cut with millimeter accuracy can result in gaps, uneven joints, and negatively affect both stability and appearance.
It is possible to attempt this yourself if you have the right tools and experience, but in most cases, investing in a professional service is well worth it.
Davidleo
29 Oct 2020 09:45
Donar34 schrieb:
You can try it yourself if you have the right tools and experience, but in most cases, hiring a professional company is a worthwhile investment.
I can only confirm this: I borrowed tools and did it myself, but it took a lot of time and patience. Milling the edge cleanly was tricky.
If you don’t want to spend a lot of extra time, it’s better to leave it to the experts!
pasau
30 Oct 2020 07:55
In summary, I conclude that building a U-shaped kitchen using IKEA Metod is basically possible if you
- use the correct corner cabinets and connecting elements
- pay attention to precise measurements and level surfaces
- and work with professionals for the countertops
Thank you for the detailed tips and the exchange! If I have any specific questions about the installation, I will gladly reach out again.
