ᐅ Is the IKEA Brimnes wardrobe suitable for a DIY renovation?
Created on: 4 Dec 2017 18:47
tanni35
tanni35
4 Dec 2017 18:47
Hello everyone, I am considering whether the IKEA Brimnes wardrobe is suitable for a DIY conversion and would appreciate your experiences and opinions. Specifically, I am interested in how the wardrobe holds up in terms of material thickness and stability during modifications. Is it sturdy enough to, for example, remove shelves, add extra brackets, or possibly fit custom elements? It would also be helpful to know how easy or difficult the existing material is to work with—such as for cutting or alterations without professional tools. Additionally, it would be great to hear whether the wardrobe’s design and construction provide a good base for a custom interior and what limitations should be kept in mind when doing a DIY conversion. Thanks in advance for your assessments—tips from practical experience are very welcome!
PULAU
4 Dec 2017 19:22
The Brimnes wardrobe is generally stable for its intended use as a clothes cabinet, mainly due to the fairly solid particleboard and metal fittings. It is well suited for light adjustments, such as removing or relocating shelves. However, it should be noted that the carcass panels are relatively thin (about 16 mm (0.6 inches)), which can lead to breakage if subjected to more forceful mechanical modifications. The material can be worked on for cuts or larger changes without professional tools, but it requires care and patience, as particleboard is prone to chipping. In general, I recommend reinforcing or adding extra supports using appropriate screws in the pre-drilled holes to maintain stability. The design is clearly structured, which generally makes later customization easier, but extensive alterations can be complicated due to the flush frame and overall construction.
goron
4 Dec 2017 20:05
Brimnes is suitable for simple modifications. Removing shelves and adding your own shelves is no problem. For larger alterations, it is less ideal, as the particleboard breaks easily. It’s best to work with hand tools and avoid applying too much force.
Gerard
5 Dec 2017 08:14
PULAU schrieb:
The Brimnes wardrobe is basically stable for its purpose as a clothes wardrobe, mainly due to the fairly solid particleboard and metal fittings.
This assessment is accurate. The particleboards used have a thickness of approximately 16 mm (0.63 inches), a typical standard in IKEA furniture. The material provides sufficient stability for the intended use, but mechanical alterations such as drilling or cutting carry the risk of chipping.
- Suitable areas for modification are primarily the shelves and adjustable shelf boards, which are usually easy to remove.
- When installing additional brackets, predefined drill holes should be used, and no new holes should be drilled into load-bearing parts.
- An interest in individual customization is understandable; however, this does not result in professionally sustainable structural changes.
Regarding the design, the Brimnes wardrobe is modular, but the carcass parts are not intended for extensive modification. For DIY projects, the Brimnes is better suited for minor changes, such as installing LED strips or replacing handles. Larger alterations should be done using sturdier furniture or custom-made solutions.
