ᐅ Is the assembly of the IKEA Brimnes furniture also manageable for seniors?
Created on: 12 Apr 2016 13:04
Gerdbu
Dear community,
I am currently considering whether assembling the IKEA Brimnes furniture set is easily manageable for seniors. My main focus is on how easy or difficult the individual components are to handle, how clear the instructions are, and whether any special tools are required that might pose a challenge for older people. Additionally, I am interested in whether the construction itself remains straightforward given the delivered parts, or if there are potential pitfalls that could make assembly harder, especially with reduced strength, limited mobility, or visual impairment.
Does anyone have experience with this, perhaps even in the senior sector, and can provide insights or tips? It would also be helpful to know if it is better for an older person to rely on external help or if the furniture is designed to be assembled alone without risk of mistakes or frustration.
Thank you in advance for your feedback!
blapau
12 Apr 2016 15:52
Hello Gerdbu,
Regarding your question about handling large panels: Yes, aids such as clamps or temporary supports on a table can be very helpful. This way, you can avoid having to support the component continuously with your arms. Another tip is to assemble the furniture on a flat, preferably elevated surface to reduce bending and lifting.
Common mistakes include:
- Not checking the alignment of the panels before securing them, which often leads to uneven results.
- Tightening screws too early, making adjustments more difficult.
- Carefully reading the instructions and paying attention to the illustrations helps prevent incorrect assembly.
For seniors, it is therefore helpful to take their time, prepare the necessary tools in advance, and ideally have someone assist with the more complex steps in the background.
Hope this helps.
Lucki
12 Apr 2016 16:10
Hey Gerdbu! Don’t stress yourself! I think Brimnes is quite doable for seniors if you take it easy. My grandparents managed it that way, with a little help from me, of course – that really lifted their spirits! Just work in small stages, and it will go well!
Sinan-meo
13 Apr 2016 10:21
The assembly of Brimnes is technically straightforward, but structural conditions can cause difficulties for users. A key factor is strength and coordination: especially when strength and fine motor skills are limited, the heavy panels should ideally be handled by two people. Changing sitting positions or taking breaks is also recommended to avoid overexertion.
If approached as a team and using aids such as sawhorses or sturdy tables, the assembly is manageable even for seniors. Safety should always be the top priority.
Gerdbu
13 Apr 2016 11:08
Sinan-meo schrieb:
If you approach the whole process as a team and use aids like sawhorses or sturdy tables, assembly is manageable even for seniors.
Thanks for the tip, sawhorses are a great idea for a stable support!
blapau schrieb:
Carefully reading the instructions and paying attention to the illustrations helps avoid incorrect assembly.
By the way, does anyone have an opinion on how clear the pictures in the instructions are for seniors? Are they presented clearly and large enough, or sometimes too small and detailed? That also plays a role in independent assembly.
nikian
13 Apr 2016 11:45
Regarding your question about the instructions: IKEA usually uses very clear pictograms and minimal text, which generally improves understanding. However, with more complex furniture, the image sequences can sometimes appear a bit small – strong reading glasses or good lighting are then very helpful. For the Brimnes set, clarity was prioritized, but you should take your time to carefully follow each step.
If you still feel uncertain, it can be worthwhile to review the instructions before starting the actual assembly or even perform small practice steps in advance to familiarize yourself with the process. Overall, I give you the green light for self-assembly, as long as the above recommendations are followed.
Lidan56
14 Apr 2016 09:55
Finally, a quick note: If you have physical limitations, it’s better to get help with the assembly. The tools required are straightforward, but strength for holding parts is a major factor. So it’s best to work with two people, then it will be easy.
