ᐅ Is screwing multiple Kallax units together a permanently stable solution?
Created on: 26 Oct 2022 09:13
Erwanmi
Erwanmi
26 Oct 2022 09:13
I am currently wondering whether screwing together multiple Ikea Kallax units can create a long-term stable structure. Specifically, I am interested in whether fastening them through the side panels or using special connectors can secure the units firmly enough so that they do not develop weak points or come apart over time, even with regular use (for example, when storing heavier items). I am interested in both practical experiences with these types of connections and advice on any potential weak spots to watch out for during assembly.
Thanks for your opinions and tips!
Josefane
26 Oct 2022 09:35
This is an interesting question that deserves more attention.
First of all: Kallax units are primarily designed for single use, where the load distribution is clear and static. When they are screwed together, these loads change, especially rotating or lateral forces can cause problems.
I wonder: What type of screws are used exactly? Are they wood screws, particleboard screws, or specific furniture connectors? The type of screw and the fasteners used are crucial. Also, how deeply the screw penetrates the material and whether the units are pre-drilled affect the stability.
There are definitely weak points in the Kallax side panels, which consist of coated particleboard – these are not necessarily designed to withstand permanent loads. Insufficient screwing can lead to material cracks.
I hope someone with experience can share which connection methods have proven effective and whether the stability really lasts over the years or is rather a temporary solution.
pikin
26 Oct 2022 10:02
Regarding stability when screwing Kallax modules together, there are several technical aspects to consider:
1. Material: Kallax is mainly made of particleboard, which has a certain load-bearing capacity but is not endlessly durable under heavy loads.
2. Screwing: Using particleboard screws with pre-drilling is advisable to avoid splitting the material.
3. Connection technique: In addition to standard screwing, using metal brackets or connectors designed specifically for furniture assembly (e.g., cam locks) is recommended, as they distribute forces more effectively.
4. Long-term behavior: Without additional reinforcement and careful assembly, repeated stress can lead to loosening over time.
Conclusion: Screwing Kallax modules together is generally feasible and can be stable if professional connectors and proper techniques are used. However, careless screwing directly through the panels can quickly compromise stability.
bauku
26 Oct 2022 10:59
Hey, this is really exciting! 🙂
A year ago, I screwed two Kallax units together – and since then they’ve been rock solid! I used sturdy metal brackets screwed inside the side panels, which makes a big difference. The typical thin screws through the board itself seemed too risky to me, as they could easily damage the material.
So, if you go this route, you’ll have a very reliable unit, almost like a seamless piece of furniture. I’m currently using mine as a small shelf in my workshop, and it has already held some heavy boxes without any movement.
Please don’t just screw them together from the outside – there are better methods for long-lasting stability! 🙂 🙂
jan10
26 Oct 2022 11:13
Screw the modules together on the inside at the contact points of the side walls using metal brackets. Screws without brackets tend to loosen over time. To ensure safety, pre-drill.
TARAON
26 Oct 2022 14:27
The idea of connecting multiple Kallax units into a stable assembly is brilliant, and yes, the process is not that complicated! 😊
My tip: Don’t just place the units tightly together—give them a little “glove fit” by using small corner brackets at the inside joints. This ensures a good balance between material integrity and stability.
And hey, don’t worry about drilling—with the right care, the material will handle it. It’s a bit like two friends shaking hands! 😉
This way, your shelving will serve you well for a long time to come.
