Hello everyone, I recently bought an Ikea Pax wardrobe system and am considering how easy it is to retrofit lighting elements into such a system. Specifically, I’m interested in whether Ikea’s own wardrobe lights or alternative LED solutions purchased externally can be installed without much effort. Is retrofitting lighting elements in Ikea Pax systems generally straightforward, especially without professional electrical training? What tools and preparations are needed, and how complicated is the daily connection or installation of the lights? It would also be interesting to know whether better results are achieved with Ikea’s own light strips or with third-party accessories. Does anyone have experience or tips? Thanks in advance for your insights!
kaubi schrieb:
I was about to ask what exactly your current Pax setup looks like – do you have the back panel with cutouts or just plain wooden panels?This question is relevant because a back panel with cable openings makes retrofitting much easier. Additionally, the electrical connection options should be considered: Do the voltage and plug type of the lighting element match those of the Ikea Pax systems?
From a technical perspective, it is important to carefully read the installation manual to avoid possible short circuits. If third-party components are installed, you should not exceed the maximum power rating to avoid overloading. The lights available from Ikea are designed to work harmoniously within their compatible system.
To complement the previous posts: For retrofitting lighting elements in Ikea Pax wardrobes, I recommend the following approach:
- First, take precise measurements of the wardrobe and plan the desired lighting positions.
- In a second step, decide whether to use Ikea’s own lights or third-party LEDs. Ikea lights are more convenient because they fit perfectly and are easy to install. Third-party products offer more flexibility but require more preparation.
- If using third-party products, it is advisable to use flexible 12V LED strips with an external power supply. This simplifies power management and reduces risks.
- The rear panel of the Pax can be either a full panel or have cable openings. For retrofits without changing the rear panel, you may need cable pass-throughs or modifications.
- Cable management is important; there are various clips and channels available to route cables discreetly.
- Finally, carry out the installation according to the instructions, ensuring secure connections and proper insulation.
Here is a tip: If you are unsure, you can also hire a skilled handyman or electrician who can complete the retrofit in 1-2 hours and guarantee safety.
Reosu schrieb:
Is retrofitting lighting elements in Ikea Pax cabinets actually easy to manage, especially if you don’t have professional electrical training?To address this specifically: Yes, retrofitting Ikea’s own lighting elements in Pax cabinets is quite doable for technically skilled DIYers and does not require professional electrical expertise. The plug-in systems are safe, and the assembly instructions are clear. Of course, how “easy” it is depends on how many elements you want to retrofit and how the existing setup is constructed. For custom LED solutions, I recommend carefully checking the wiring diagram and voltage before the first installation, and if in doubt, it’s better to stick with Ikea products. As for tools, you’ll need at least a screwdriver, a utility knife for cables, and possibly a drill for extra holes. In summary: Retrofitting Ikea’s own system is straightforward—even without professional training. Third-party lighting systems are somewhat more demanding and require at least basic technical knowledge.
