ᐅ Is it easy to add lighting elements to Ikea Pax wardrobes?
Created on: 31 Mar 2024 09:12
Reosu
Reosu
31 Mar 2024 09:12
Hello everyone, I recently bought an Ikea Pax wardrobe system and am considering how easy it is to retrofit lighting elements into such a system. Specifically, I’m interested in whether Ikea’s own wardrobe lights or alternative LED solutions purchased externally can be installed without much effort. Is retrofitting lighting elements in Ikea Pax systems generally straightforward, especially without professional electrical training? What tools and preparations are needed, and how complicated is the daily connection or installation of the lights? It would also be interesting to know whether better results are achieved with Ikea’s own light strips or with third-party accessories. Does anyone have experience or tips? Thanks in advance for your insights!
fredle
31 Mar 2024 10:47
Hello Reosu, I have retrofitted the Ikea Pax system with several lighting elements and can describe the process quite well from my own experience. Basically, Ikea focuses on easy assembly and retrofitting—especially with their own lighting elements like the "Släck" or "Nypa" LED lamps. The advantages are: - Installation using magnetic mounts or snap-in fittings, often without drilling - Plug-and-play with Ikea’s own power rails (these are quite simple to connect) - Connectors that are easy for non-professionals to handle However, there are a few things to keep in mind: - The Pax back panel usually needs slight modifications for cable passthroughs; often there are pre-made holes for this. - If you want to use external LED strips, you might need additional tools (e.g., drill, wire stripper). - Power supply is usually provided through Ikea’s bus systems or standard power adapters; the latter requires more wiring knowledge In summary: Retrofitting Ikea lighting elements is really quick and easy, while external accessories can be more challenging depending on the model and your electrical skills. I recommend reading the exact installation instructions before purchase and consulting an electrician if you are unsure. If you like, I can also provide you with a step-by-step guide.
kaubi
31 Mar 2024 14:03
Hello Reosu, to answer your question in detail, it is important to look at the topic of lighting elements in the Ikea Pax system from a technical perspective. Basically, there are two types of lighting: Ikea’s own solution and third-party products. Ikea’s own lights are usually designed to fit the pre-made holes and slots in the Pax system, meaning the back panel often includes areas for cable channels or holes for wiring. This makes retrofitting much easier for you. The light strips mostly come with plug connectors that you simply connect and integrate into the system.
For third-party LED strips, the following applies:
- You need to check if the length of the light strip fits or if you can shorten it (Ikea strips have marked cutting points).
- Installation is often done with double-sided tape or magnetic holders, which you have to provide yourself.
- The power supply needs to be connected individually, especially for fixed installations, possibly requiring a separate power supply unit and switch. It is important to ensure proper insulation of any self-laid cables to avoid the risk of short circuits.
I was just about to ask how exactly your current Pax version looks – do you have the back panel with an insert or simple wood panels? That says a lot about how straightforward the retrofitting will be. Also, are you planning a fixed, permanent installation or more of a temporary setup? The answer here can influence the choice of lighting elements.
Jukin
31 Mar 2024 15:26
Hello Reosu, I had the exact same question some time ago. From my experience, retrofitting lighting elements on the Ikea Pax system is quite manageable for people who are not very technically experienced. The system is designed for DIY enthusiasts to add lights without requiring advanced technical skills. I used the "MÖJLIG" light strips in my setup and simply glued them to the inside top of the wardrobe, routed the cables through the provided openings, and connected them to the included power plug. You should pay attention to cable routing to avoid anything being pinched, especially with drawers. If you don’t have a fixed built-in switch, a power outlet with a switch inside the wardrobe nearby can often help. I also recommend using 12V LED lights with your own accessories, as they are safer and most Ikea lights operate on low voltage as well. One friendly request: if you let us know whether you plan to disassemble the wardrobe or keep it in place, we can give you even better advice. Good luck!
TEOZAR
31 Mar 2024 18:54
fredle schrieb:
The advantages: - Installation using magnetic mounts or snap-in clips, often without drilling - Plug-and-play with Ikea’s own power rails (these are quite simple to connect) - Connectors that are easy to use even for non-experts
I can fully agree with that. I have retrofitted both the "Rimforsa" cabinet lighting and a few small LED spots myself. In Ikea systems, almost all cables and components are designed so that the user hardly needs to do any soldering or major electrical modifications. You just have to make sure to connect the power source properly and observe the circuit breakers in the house.
It is also important to have tidy cable management inside the cabinet sometimes—I used small cable clips from the hardware store for that, which helps if the cabinet is used frequently. The installation is not extremely difficult, but you should take some time for it.
lisku
1 Apr 2024 07:44
In short: Installing Ikea lighting components into a Pax wardrobe is simple. Screw or stick them in, plug in the power, and you're done. For third-party LEDs, you just need to pay attention to the correct voltage and drill holes. Open the wardrobe beforehand and make some space.
