ᐅ Is PAX suitable for use in damp rooms?
Created on: 31 Jul 2021 14:07
nathanmo
nathanmo
31 Jul 2021 14:07
I have a question that has been on my mind for some time, and I would like to hear expert opinions here: Is PAX suitable for use in humid rooms?
Specifically, I am interested in whether the PAX furniture series, especially the cabinets, which are often made of particleboard and plastic, can withstand long-term use in a humid environment such as a bathroom or a basement that is sometimes damp. What should be considered when using PAX in such conditions? Are there any special protective measures, or is it recommended to use it only in well-ventilated, dry indoor spaces?
I would also be interested in any experiences regarding how humidity affects the material properties and functionality (e.g., hinge mechanisms).
I look forward to your assessments!
FELOTAU
31 Jul 2021 16:22
nathanmo schrieb:
Is PAX suitable for damp rooms as well?
Hello, I think your question is very important, especially since moisture is often underestimated. I personally had PAX wardrobes in my basement, which was occasionally damp. Unfortunately, the carcasses were damaged by the moisture. The panels swelled at the edges, and after a while, the doors no longer closed properly. That was really frustrating.
What I learned from this is that while PAX furniture seems sturdy, it is not really designed for permanently damp environments. If the humidity is briefly elevated, it’s somewhat manageable, but consistently high moisture affects the particleboard significantly.
Personally, I would recommend using PAX only in dry, well-ventilated rooms. If you still want to use it in a bathroom or basement, make sure there is good airflow and consider using moisture absorbers. However, I cannot guarantee it will hold up over time.
I hope this helps you for now!
LANICOLE
1 Aug 2021 09:13
Good morning everyone! I would like to explain the question "Is PAX suitable for humid rooms?" from a technical perspective.
PAX wardrobes are usually made from melamine-coated particleboard. These boards are not waterproof, only water-resistant. Specifically, this means:
- In conditions of high humidity or direct moisture (water splashes, condensation), the boards can swell.
- The glued joints may come apart.
- Metal parts, such as hinges, are zinc-coated, but constant exposure to warm, moist air can promote rust.
Therefore, IKEA itself recommends using PAX only in dry, well-ventilated indoor spaces.
If you want to use PAX in humid rooms, you can consider the following:
- Ensure sufficient ventilation and low humidity.
- Protect the floor and wall behind the furniture, for example with waterproof sheets.
- Avoid direct contact with water.
- Additional protective coatings might be applied to the furniture, but this is not intended by the manufacturer and requires professional know-how.
In short: PAX is not really designed for bathrooms or damp basements. For these rooms, furniture made of plastic, stainless steel, or special waterproof materials is more suitable.
I hope this technical summary clarifies the topic a bit.
kaju67
2 Aug 2021 19:34
I fully agree with that and am glad to see such detailed explanations here. I find this topic really interesting because I’ve also considered placing a PAX unit in my damp hobby room.
Despite the technical facts, there is always the attempt to make it work—maybe with a few tricks:
- Definitely leave at least 5cm (2 inches) of space from the wall to allow air circulation.
- Use moisture absorbers inside the cabinet; that really helps.
- Maybe seal the edges with silicone sealant to slow down swelling.
But will that be enjoyable in the long run? Hmm...
As the saying goes: sometimes it’s worth sacrificing the rustic charm of something if a piece of furniture just isn’t suited to the environment. So it’s better to be safe and look for something specifically made for damp rooms—even if it’s not as stylish.
You don’t want to constantly deal with frustration and complaints when the PAX warps after a few months.
pinDavid
3 Aug 2021 11:47
nathanmo schrieb:
Is PAX also suitable for damp rooms?
PAX is not designed for damp rooms. If you still use it, then:
- Ensure good ventilation
- Use dehumidifiers
This helps somewhat but does not replace water-resistant furniture.
