ᐅ Is it possible to power my shed with solar energy for lighting and electricity?
Created on: 27 Sep 2016 16:35
sauerpeter
sauerpeter
27 Sep 2016 16:35
Our build is still in the planning phase, so the electrical connection has not yet been installed on the property.
At the back of our lot, we have a shed that we are currently using as a "break room" when working on-site. No, in case you’re wondering, we are not moving in or sleeping there. It’s just about having some light for a few hours in the evening during the darker season until we leave to go home again.
My initial idea:
Buy solar lamps with a solar panel. Mount the panel outside and the light inside, so when we are there and need light, we switch it on. The problem: I want one without a motion sensor or at least one where the motion sensor can be turned off. I prefer a light that has to be switched on and off manually. So the lamp is really only on when needed. Of course, a motion sensor only activates when there is movement, but I don’t want to keep waving around to trigger it constantly.
I was also thinking, maybe some power can be generated by a solar module? Always assuming this only needs to last a few hours.
Do you have any ideas? The most important thing is to have light first. I have already searched online but mostly found options with motion sensors.
garfunkel
27 Sep 2016 18:27
Cable drum and that's it
nelly190
27 Sep 2016 18:49
Maybe the camping section is the right place for you. A solar panel with a car battery as a buffer storage and suitable 12 V lights.
sauerpeter
28 Sep 2016 09:27
garfunkel schrieb:
Cable reel and that’s it
And where do I plug in the cable from the cable reel?
hbf12
28 Sep 2016 09:47
Maybe this is what you are looking for Solux LED 50 or 105
Deliverer
28 Sep 2016 11:38
With two LED work lights and two pack batteries, you can get through the winter.
Possibly also rechargeable site floodlights – which you will still need afterwards.
Both options are likely better in terms of cost and ecology than dealing with solar panels in winter.
