ᐅ Is KfW 40+ achievable with a decentralized ventilation system?
Created on: 4 Dec 2019 08:00
SpeckiGood morning,
I have a question that I couldn’t find a clear answer to on the internet. Maybe someone here knows for sure. For a KfW 40+ residential unit (it will be a multi-family building), is a central ventilation system mandatory, or is a decentralized ventilation system with heat recovery also acceptable?
I believe a decentralized system should be possible since KfW requires ventilation systems with at least 80% heat recovery efficiency, which some decentralized systems can achieve. However, I have also read in some places that a central system is mandatory.
Maybe you can provide more information on this. Thanks in advance.
Specki
Specki
boxandroof4 Dec 2019 09:27Decentralized systems are probably more practical for the apartment than centralized ones. Both options are feasible. Whether it can work entirely without would need to be calculated. As far as I know, it is not explicitly required, but I would expect that compensatory measures like additional insulation are more expensive and less effective.
Two quotes from the KfW website:
However, I could not find any specification on the KfW site whether these systems are decentralized or centralized.
And on the internet, I find contradictory information.
- A KfW Efficiency House 100, for example, meets the requirements of the Energy Saving Ordinance.
- A KfW Efficiency House 55 requires 55% of the energy of the reference building, and a KfW Efficiency House 40 only 40%.
- For the KfW Efficiency House 40 Plus standard, additional equipment and systems are required, such as for electricity generation and ventilation.
Here are the Plus components in detail:
• an electricity-generating system based on renewable energy on the property. Photovoltaic systems are most commonly used, or combined heat and power units; wind power is rare,
• a stationary battery as an electricity storage device,
• a ventilation system with heat recovery,
• a digital user interface that visualizes electricity generation and consumption.
boxandroof4 Dec 2019 11:59Controlled residential ventilation is not an optional add-on, even if it might be stated that way by the KfW itself and you might practically not be able to avoid it. A central system is not mandatory. You need to meet specific requirements for KfW 40 (without +), and the path to achieve this is not strictly defined, even if the KfW examples suggest otherwise.
You will have to carry out a calculation.
