I’m currently considering whether an IKEA KALLAX shelf unit could serve as a kitchen island in the long term and what advantages and disadvantages this might have. Specifically, I’m interested in whether the material and workmanship can withstand the demands of a kitchen island over time—such as exposure to moisture, heat, potential loading from kitchen appliances, or cutting on the work surface.
I would also like to know how practical the KALLAX units are in terms of storage space, modularity, and ergonomic height for everyday kitchen use. Can it really be a durable alternative to traditional kitchen islands when fixed in place, or is it more suitable for temporary setups?
I’m looking forward to hearing your experiences and opinions. Thanks in advance!
Hello mobolo,
very good and thoughtful question!
Basically: yes, the KALLAX shelf can be used as a kitchen island in principle, but there are a few points you should consider. The KALLAX is made of MDF and particleboard, which means it can swell or warp if exposed to direct water contact or constant moisture. So definitely apply a sealed surface or an additional protective layer, especially for a kitchen island that often gets splashes or hot pots.
Regarding ergonomics: the standard height of KALLAX is rather low for a kitchen countertop (about 38 cm (15 inches) per unit), so usually two levels stacked are necessary to reach a comfortable working height of 90–95 cm (35–37 inches). This makes the island quite tall and it needs to be well stabilized.
As for storage space, KALLAX is very modular, but the compartments are not as deep as typical kitchen cabinets. It is sufficient for dishes or smaller appliances, but large pots or pans won’t fit well.
Brief summary: if you protect the material and adjust the height, KALLAX can be an affordable and flexible kitchen island – but for permanent use, quality and sealing should be carefully considered.
The comment from sarlo is quite accurate – I would like to add a few technical details regarding the durability and load capacity of KALLAX when used as a kitchen island:
- The KALLAX system is not designed for kitchen use. The panels are mainly made of medium-density fiberboard (MDF) and are coated with melamine foil. This coating provides some moisture resistance but is not waterproof with direct contact or prolonged exposure to moisture.
- Heat: The surfaces are not heat-resistant. Placing hot pots or pans directly on them will eventually cause discoloration or damage.
- Structural stability: Individual KALLAX units are fairly sturdy, but for taller constructions (e.g., stacking two units), additional reinforcement is recommended, such as screwing or bracing, to prevent wobbling or tipping.
- Ergonomics: The typical kitchen worktop height ranges between 85 and 95 cm (33 to 37 inches). A single KALLAX unit is about 38 cm (15 inches) high – so two units plus a stable countertop are required. This can make the construction heavy and unwieldy.
Conclusion: KALLAX units are only partially suitable for a kitchen island intended for regular use, mainly due to the material's resistance and the necessary modifications. They can work for temporary solutions or as an inexpensive additional island with protective measures, but for long-term kitchen demands, significant limitations apply.
sarlo schrieb:
"... The standard height of KALLAX is rather low for a kitchen countertop... so usually two units stacked are needed..."That’s already very helpful, thanks! I was considering placing a suitable countertop on top (for example, wood or stone), which would also be more heat resistant than the KALLAX surface itself. But how stable are two stacked KALLAX units really? Do they absolutely need to be screwed together, or can they stand securely without fastening?
Also interesting: What about cleaning? Handles or open compartments—if you use it as a kitchen island, which tends to get dirty more often—what works better?
I’d appreciate if anyone else could share their thoughts on this—or if there are any firsthand experiences that go beyond just theory.
Hello mobolo,
you’ve clearly put a lot of thought into this! 🙂
From my experience: I built a kitchen island myself using two KALLAX units and placed a thick wooden countertop on top. It looks great, is very flexible, and is fun to use!
The stability is better if you screw the units together or connect them with brackets. Otherwise, it tends to wobble too much under load.
Open shelves naturally get dirty faster, especially if you’re working with food. Handles and doors protect the storage better but require a bit more maintenance because of the handles themselves. I recommend open shelves with attractive boxes—you can access things quickly, and not everything is fully exposed.
All in all, it’s a great, affordable solution! With a well-sealed countertop and some care, you’ll be well set. Good luck! ;-)
mobolo schrieb:
"How about cleaning? Handles or open shelves..."
