ᐅ Is a Kallax shelf sturdy enough for rattan inserts?
Created on: 25 Aug 2021 08:17
fukeo64
I am planning to get a Kallax shelving unit from Ikea and want to use rattan inserts to give the shelf a more natural and cozy look. However, I have a question: Are Kallax shelves actually sturdy enough to hold rattan inserts securely and permanently, especially when storing somewhat heavier items?
Specifically, I am interested in whether the typical construction of the Kallax (that is, MDF panels with a white coating and relatively simple slot connections) is stable enough to support the lateral load and possible weight of the rattan baskets without the unit warping or getting damaged over time.
Maybe someone has personal experience with this, especially when the rattan inserts are somewhat larger and heavier?
I look forward to your opinions and advice!
Fitigu
25 Aug 2021 10:18
The Kallax shelves are generally stable enough for their intended use. The MDF panels have sufficient thickness, and the joints hold up under normal loads.
With rattan inserts, it should be noted that they are often hung rather than resting flat. This can lead to point loads, which could theoretically cause pressure marks.
To increase stability, it is recommended to:
- Assemble the shelf correctly and securely using all mounting components.
- Anchor it to the wall.
- Distribute heavy loads across multiple compartments.
For typical residential use with rattan inserts, this does not pose a significant risk.
TAUPLO
25 Aug 2021 11:02
benfa schrieb:
The plug connections themselves are not screwed in, but plugged together.
That's true, you do need to be a bit careful, but honestly: a Kallax can handle more than you might think. If you treat the shelf properly, don’t overload it, and are a little cautious when putting things in, there really shouldn’t be any problem.
Fitigu schrieb:
Anchoring it to the wall
I fully agree with that advice! Especially when people put more weight in the corner, wall mounting is definitely essential.
Otherwise, have fun setting it up—I think it’s a really great combination!
fukeo64
26 Aug 2021 07:46
I have reviewed the feedback again and see that wall mounting is likely a good idea to ensure long-term stability. The concept of distributing the load across several compartments also sounds reasonable.
benfa schrieb:
to be mechanically relieved, for example by additional screws or anchors into the wall
Would adding a crossbar behind the shelving unit to stabilize the individual compartments from the back be a good option or rather unnecessary?
If anyone has tried this or could share their experience, I would appreciate the feedback.
Lidan56
26 Aug 2021 08:12
Crossbars are a practical solution. They stabilize the back panel and prevent twisting.
I used this with my Kallax shelving unit, and it works well. Don’t forget to secure it to the wall.
LAYNE
26 Aug 2021 08:55
fukeo64 schrieb:
Would adding a crossbar behind the shelf to stabilize the individual compartments from the back be a good option or rather unnecessary?
Definitely a smart idea! A crossbar greatly increases stability and prevents sagging over time. It’s good that you’re considering this.
Kallax is sturdy on its own, but a bit of reinforcement here and there often makes sense—especially if you plan to dress up the shelf with rattan inserts and want to enjoy it for a longer time. 🙂
