ᐅ Is it worth retrofitting soft-close mechanisms for IKEA Hemnes doors?
Created on: 23 Jun 2017 18:42
benkeoI am currently considering whether it is worthwhile, in terms of user comfort and durability, to retrofit the IKEA Hemnes doors on my dressers and cabinets with a soft-close function. My main questions are: Is the installation technically straightforward without requiring significant effort or modifications to the furniture? Does adding soft-close noticeably improve the user experience enough to justify the effort and cost? And are there any benefits regarding the longevity of the doors or hinges when soft-close is installed? Since IKEA Hemnes furniture is generally built in a classic style, I am unsure whether integrating soft-close hinges will work smoothly or if problems might be expected. Has anyone here had experience retrofitting soft-close on Hemnes models and can offer advice on choosing the right hinges?
The idea makes a lot of sense, especially if you frequently close doors and value increased comfort. To explain the basics first: Soft-close hinges work with a damper that prevents doors from slamming shut.
For IKEA Hemnes, retrofitting is generally possible, but you need to make sure that the new hinges are compatible with the existing mounting system or can at least be adapted with small additional drill holes. Many soft-close hinges are designed for standard 35mm (1 3/8 inch) cup screw holes, which are often found on IKEA doors, making the task easier.
The increase in comfort is usually noticeable: doors close more softly and quietly, which is especially appreciated in busy households. The furniture is also less stressed, as the heavy impact of slamming is reduced.
Regarding costs: you should expect around 10-20 euros per hinge, plus some labor time if you do it yourself. Whether it’s worth it depends, of course, on how much you value comfort. In terms of durability, I would say soft-close hinges can help reduce long-term damage to doors and fittings, since the impact stress caused by slamming is significantly lessened.
benkeo schrieb:
Is the installation technically straightforward without major effort or modifications to the furniture piece?
benkeo schrieb:
Does retrofitting actually improve usability significantly enough to justify the effort and cost?
In addition to marix’s comments, I would like to add from a technical perspective that the quality of soft-close components varies significantly. Cheap models may lose their damping effect over time or cause mechanical issues.
So, those who invest should opt for branded or proven quality products. IKEA, for example, offers its own soft-close hinges that ensure a good fit.
Technically, soft-close dampers reduce the impact on the door and hinges, which can extend the lifespan of the fittings. However, installation should be done carefully to ensure the mechanism works properly and does not wear out prematurely due to incorrect adjustment.
Finally, a note: Not every Hemnes door is the same, and some models with thicker or very heavy doors may require special hinges that might not be easy to retrofit.
benkeo schrieb:
Are there any advantages in terms of the durability of doors or hinges when soft-close is installed?
Soft-close is worthwhile if you find slamming annoying or want to reduce noise. Installation is usually straightforward if you choose a standard hinge with soft-close that fits Hemnes.
If you want to do the installation yourself, you will need a cordless drill and patience for the adjustment. The doors last longer because closing is gentler.
Costs are reasonable, but only if you buy the parts separately. IKEA also offers suitable sets, which help avoid issues with incorrect measurements.
