Hello everyone, I am planning to make my Ikea Platsa system more flexible by considering whether the individual furniture modules can be mounted on casters. My question is: Are there ways to convert Ikea PLATSA furniture to make it mobile by installing casters? It is important to me that stability and functionality are maintained. Do you have any experience with this, or do you know if there are special caster models or mounting kits that are well compatible? Thanks in advance for your insights and tips.
Ikea PLATSA furniture consists of modular units that are typically designed without casters. To install casters, the following procedure is recommended: - Select furniture casters with an appropriate load capacity (depending on the weight of the individual module) - Attach them to the underside using compatible screws or mounting plates - Reinforcing the base panel or using additional plates can improve stability. However, the furniture should be stable enough to remain upright when mobile, otherwise it might tip over. Casters should ideally be lockable to ensure a secure standing position.
KAULIS schrieb:
Ikea PLATSA furniture consists of modular units that are usually designed without casters. To install casters, the following steps are recommended: - Select casters with an appropriate load capacity (depending on the weight of each module) - Attach them using compatible screws or mounting plates on the bottom - Reinforcing the base panel or using additional panels can improve stability. However, the furniture should be stable enough for mobility; otherwise, it may tip over. Ideally, the casters should be lockable to ensure a secure stand. Thank you for this detailed answer! In your opinion, what would be the best way to reinforce the base panel without significantly changing the visual appearance of the PLATSA furniture? Are there any recommended materials or methods for this?To reinforce the base panel of Platsa furniture, the best option is a piece of plywood attached underneath the base panel. The advantages are: - Plywood is strong, lightweight, and stable - It can be cut thinly, so it does not significantly increase the height - With appropriate screws, it can be mounted almost invisibly Alternatively, sturdy angle brackets can be used, which are screwed underneath the base panel from the inside. This solution preserves the external appearance but requires some DIY skills for installation. Pay attention to the load capacity of the casters and choose lockable models to minimize the risk of tipping.
